possibly oil in coolant
Old Jan 9, 2009 | 03:55 PM
Bobz08C6's Avatar
Bobz08C6
Default possibly oil in coolant
I may be getting engine oil in my radiator but I'm not getting coolant in my oil in my '73 SB auto, a/c car.
At first I thought it might be a head gasket but now I'm thinking it isn't. I did an exhaust gas test for the presence of exhause gas in the radiator and it came back negative. The plugs look o.k. I don't think a compression test will help and I can't do a proper leak down test on each cylinder because I don't have the tool.
What are the chances the oil cooler lines within the radiator are leaking the oil into the coolant portion of the radiator end caps?
I'm almost ready to replace the radiator to solve the problem but they are so expensive and such a pain in the a** to install that I would kick my car in the fender if it didn't solve the problem.
Old Jan 9, 2009 | 04:34 PM
SIXFOOTER's Avatar
SIXFOOTER
What leads you to think there is oil in the coolant?
Is this a new thing or is the car new to you? I have seen some "Stop Leak" treatments that look like oil in the coolant.
Old Jan 9, 2009 | 05:20 PM
Bobz08C6's Avatar
Bobz08C6
Additives in the system is something I hadn't thought of. Could be something to consider.
I recently purchased the car in Nov and drained, flushed and added 50/50 to be sure it was ready for the Michigan winter. The pan the old coolant was drained into, when emptied, was coated with "oil". The "scum" on the surface of the new coolant in the radiator looks like oil as well when wicked out with a rag.
The car is under wraps in the garage until spring so I don't have a chance to drive it at all. It starts, idles and runs well and does not overheat at all. No coolant or oil leaks. Here is a pic of the pan. Sure looks like oil.
Old Jan 9, 2009 | 06:08 PM
RHD '68 L89's Avatar
RHD '68 L89
Heres a possible "Worst Case Scenario"
I had an engine which had engine oil in the cooling system. I had the heads checked out, they were fine. Head gaskets were fine. I ended up stripping the motor back to a bare block and putting kero in where the water should be, blocking off ports and such. I used kero because it is "thinner" than water and will dissolve any oil which got in it's way.
The first side was fine so I drained it and rotated the block to bring the other bank up level and filled it with Kero. After leaving it overnight there was a few drops on the catch paper I had put underneath.
What it was was a porosity between the cooling system and the oil gallery. I could see the track of the kero from near a cam bearing.
Oil under pressure could get to the water but water stayed out of the oil.
I replaced the block and had a great doorstop for the garage door.
I do hope this not your problem.
Old Jan 9, 2009 | 06:20 PM
Bobz08C6's Avatar
Bobz08C6
Thanks for the input RHD. I hope you are wrong. If not I would then replace the engine with a ZZ4. The Vette is a '73 with the original engine so it probably isn't porosity but could be similar with a crack instead of porosity. The engine was rebuilt with some performance characteristics 1,170 miles ago before I owned the car. I have only put 3 miles on the car before it went in the garage for the winter.
Old Jan 9, 2009 | 07:59 PM
jackson's Avatar
jackson
Since this car has an automatic trans ... it has a trans cooler integrated into passenger side OE rad tank. You'd better check real close if there's a trans fluid leak into rad or vice versa. Lemme warn you ... check it ASAP ... because if you also have coolant leak into auto trans ... it will quickly wreck the trans ... the friction plates are designed to run in a petro-based bath (trans fluid) ... the coolant will dissolve the water-based glue that adheres the friction material to the friction plates ... it'll shuck the friction right off of the plates ... and only a few spoonfuls of water/coolant will wreck it ... quick too.
Old Jan 9, 2009 | 08:19 PM
tnovot's Avatar
tnovot
Any chance you could contact the previous owner to find out if he noticed the problem (I'm betting he did) and what, if anything, he did to try to find the cause? Just a thought to keep you from covering the same ground.
Terry
Old Jan 9, 2009 | 08:20 PM
SIXFOOTER's Avatar
SIXFOOTER
Well, looks like you definately got oil from somewhere. The tranny cooler is a possibilty, bypass it and flush the cooling system with GM system flush and see where ya are. Also pull the tranny pan and look in there, hopefully no coolant.
Old Jan 10, 2009 | 10:11 AM
Bobz08C6's Avatar
Bobz08C6
Thanks for all your help guys. Pretty scary stuff. I'm highly confident it's oil and not tranny fluid. I can see cooler lines attached to the right side rad end cap. I just hate to replace the rad only to find out it's an internal engine problem but I don't know how to diagnose the issue to be sure.
Old Jan 10, 2009 | 01:28 PM
wnmech's Avatar
wnmech
I know this may sound kind of dumb but have you tried to smell the liquid that is in your drain pan? Transmision fluid and motor oil both have distinctive different smells.
Old Jan 10, 2009 | 02:59 PM
Bobz08C6's Avatar
Bobz08C6
That's actually not a bad idea. I went out and smelled the tranny dip stick and then the residue on the sides of the container. It doesn't smell like the tranny fluid and the tranny fluid on the dip stick is clear and red.
Old Jan 11, 2009 | 04:07 AM
71coupe454's Avatar
71coupe454
Now that you have flushed the system, just check it close and see if the contamination reappears. Never know who poured what in it before you got it. And watch trans fluid!
Old Jan 11, 2009 | 09:25 AM
Bobz08C6's Avatar
Bobz08C6
I'm going to do just that. But first, since the oil sits on top of the coolant in the radiator I'm going to use oil absorbant cloth strips that absorb oil but not water to soak up anything that is left.
I'm also going to disconnect and plug the oil cooling lines that connect to the radiator side tank and do an air pressure decay test on the oil cooling part of the radiator. If there is no pressure decay there is no leak.
To possibly oil in coolant
