I would get two new IAC's from Autozone, NAPA,or somewhere. Don't muck them up or anything. Pull the olds ones out and adjust the pintle of the new ones to match the old ones (They should screw in and out to adjust). Once the depth is the same install them carefully.
If it works, done. If not, return them and get your money back.
Could you post a picture (several) of your carb with the engine running at cold startup and when warm? And what is your timing set at.
There is Vacuum suction on the 3/4" Diameter aluminum tube that comes out of the passenger side valve cover!, even when the PCV valve vacuum line on the other side's valve cover was removed, when i cap this alum tube the car idles close to what i think is normal.
Then I checked the timing, (yes, I unplugged the tan w/blk wire to do it) it was set high about 12*b, so i set it to 6*,
with that aluminum tube plugged idle is very low, with it hooked up to the air cleaner i'm getting an idle of about 950 to 1250 and sometimes i need to blip the throttle to get it to go down to 950ish, but that still seems a bit high.
I don't remember. My car is stored for the winter. I don`t think there should be vaccum on that tube.
Have you check the EGR valve? Is it sealing. If you push up on the orfice the idle should change. If it doesn't its not working.
Do you still have the polution control stuff on the car? Those copper tubes in the exhaust manifolds all come together. Between them and the rubber hoses is a one way valve. There is one on each side. They go. Check them as well.
I checked that forum and like your car theirs too seem to be hibernating for the winter.
Where is the EGR orifice?
YES, this car seems to have all pollution controls in tact.
it is a CA car, but i think not much different than the other 49 state emission in 1982 Corvette.
What are the symptoms when the one-way valves 'go"?
Thank you!
Its all interconnected. Unplug the hoses from the front TBI that go to the polutution control switch. Also unplug the hose that goes to the EGR solenoid and cap that port. For the purpose of getting the idle down having this stuff disconnected won't hurt. Now if there is no change then you might as well leave it hooked up.
Have you messed with the throttle control screw on the front TBI? Is the weld broken? Its factory welded. If the weld is broken it may have been tampered with.
Its hard to figure this out over the net. Being there would make it easy. But its all we got...
i have exactly the same problem. when i plug off the hose on the drivers side going into the bottom of the air cleaner the revs drop to normal ,thier is a strong vacuum presant. someone said that hose is to do with the pcv .if so ,why should it have such a strong vacuum ???
With that hose unplugged you have a vaccum leak so the idle will go up. There should be strong vaccum on it. That hose opens the door in the cleaner to allow more air in. It sounds to me like the orfice in the air cleaner that controls the door is shot and resulting in a vaccum leak. Or it could be the temperture sensor air bleeder valve.
Follow the hose from the tbi. It plugs unto the temperture sensor bleeder valve. When the sensor reads 100 degrees it opens allowing the suction to open the door in the snorkel. Something on yours is not working. It could be the bleeder valve, the hose or hoses or the orfice.
High ilde on an 82 is most always a vaccum leak. The ECM contols the idle. The ECM will loss the battle if the leak is too extreme. It will fight to lower the idle by adjusting the fuel/air mixture. The result is high unstable idle. The car will run rough.
Suction is not normal on that tube. Its a vent and should work in the reverse. It vents blowby from the rings. It should not be sucking. did you change the PCV as recommended?
You are going to have to replace the gasket on the top plate. The one the TBI's sit on. Change the TBI gaskets too. You really need to eliminate this as a source of vaccum leak. Otherwise you will chase this problem for ever.
3/4" pass side tube
With the pcv valve pulled out of the drivers valve cover, there should be no vacuum in this tube. If anything, depending on the amount of engine blowby, and at higher rpm, you should have a slight bit of pressure.
With the pcv valve in place, you will see a slight vacuum at idle (5" or less).
Egr valve
Test this with a hand vacuum pump, opening it with vacuum will make the engine run very rough, smooth with no vacuum (egr closed).
You have a vacuum leak somewhere below the throttle plates, but my long distance diagnosis would be the intake to head gaskets.
Try the propane into the 3/4 pass side tube to confirm.
i think you mean the smaller hose going to the snorkel at the front of the air cleaner? ime meaning the larger one that snakes up under and into a spout inside the air cleaner...it has a strong vacuum..when i plug it the idle lowers to a more normal rpm
