Thanks to all who have helped get things to this point. I finally got the engine in the car and am bolting things up (unfortunately my return to college is interfering with this, calculus, ugh).
In any event, I've considered the possibility and have been recommended to get a spreader bar, and VBP's sales ends in a few more days.
What is the benefit here?
I am running solid motor mounts so I dont see anything moving around much, but Im far from an expert here.
Car is a 1976 w/ supercharged 383.
PS, it appears that it bolts into the upper A- arm cross bar bolts?
I C Panama City Beach.....nice spot....party ON.....
as for the spreader bar, it's a great addition.....improves stability on the front end a goodly bit, especially in a corner...it's worth the change....but here is the problem....most of the time it will not fit with a mechanical fan in place, so if you are running with electric fans, you are fine, if not...it MAY still fit, but I hear of guys saying it's hit and miss....
Gene is correct it helps alot. You can get one that will fit the engine driven fan. What you do is locate the bar with the supplied brackets, take everything off and weld the brackets up.
Yes, I am saw that and had already planned to dump the ugly clutch fan and shroud for the Taurus setup for aesthetic reasons. You're right though in that it still looks like a tight fit.
Thanks, I love PCB, "The worlds most beautiful beaches" is not just a marketing slogan.
Well, thats 2 votes for it and $100 is not much at this point. I'll call VPB monday.
I hope I dont have to go the welding route, how in the world would you get it back out afterwards?
In the early 90's I installed one of VB&P's spreader bars on my '73 Corvette I was autocrossing at the time. It seemed like a reasonable thing to do, even though I had no hard evidence that it was doing anything. After all the front suspension mounts seemed pretty substantial, and it's not like there was a long moment arm for the upper mounts to twist the frame.
Then one day I jacked the car up by the center cross member and happened to grab the spreader bar in the engine compartment. It was very difficult to twist and was clearly under a lot of tension. I lowered the car and grabbed the bar again. It twisted easily on the Heim joints just as it had when I installed it. It was very apparent that the weight of the car and movement of the suspension was more than enough to flex the frame and I became a true believer in the spreader bar's worth to maintain suspension settings for more precise handling.
I was very pleased with the quality and cost of product that VB&P sold me, however there are a number of folks that have built their own spreader bars and I'm sure some will post pictures and their cost.
Well yes, I forgot to mention that I wont be auto-crossing or anything, just a street car, but- well...ermm, OK, let's not get into how I drive my cars on the street Dont want this thread to be used against me in court some day
IMHO a spreader bar is one of most "bang for the buck" things you can install on your car. I put one on the 65 a couple years ago. It really made a difference. The front end is much tighter and solid. Hard to explain until you drive a car without a bar then one with.
I bought a spreader bar 15 years ago and never put it on since I want retain the original Fan clutch and fan. Any suggestions on how to make it work with the OEM fan?
I have a mechanical fan. I can't say it is original but it does have a clutch. You have to offset the mounts to lower the bar enough to clear the wp pulley. You kinda have to fit it to the car. Please excuse the water. I just rinsed the car off.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by Theiskell
Here is a picture of a home made one...about 40$
They do make a diffrence. Worth the money either way
OK now I'm a little confused, I have electric fans but it looks like in another pic above on the C2 that the pulley is actually in the way. Does VB&P bar go in front of the pulley on a C3 ?
Anyone have a pic of the VB&P bar in a C3 showing where it goes across ?
Here is a VB spreader bar mounted on my car. Stock pulley setup. This was a few years ago as I now have dual fans on an aluminum radiator but the bar is the same.
There are actually 2 different ones from VB. The one I have is pre welded. They also sell one that you weld up to the brackets and I think that is the one pictured above. 73jst4fun had one that he welded up and it looked similar to that one.
Can't imagine you're still on the fence after the feedback thus far. If so, be assured this is a sound addition to any C3, autoX or not. Go for it.
Just waiting for VBP to open monday- I have a sticky on my computer to call them.
Thanks everyone for the input. CF is a great place, I hope I put in 1/10th of what I get out of it!
It'll just have to sit while I get all the other loose ends tied up on this project, but my cat needs some new car parts to look at since her pile is slowly moving out to the garage and being installed.
