Damper diameter...
Old Jan 13, 2009 | 12:11 PM
73StreetRace's Avatar
73StreetRace
Default Damper diameter...
My stock damper has an 8" outside diameter.
Many replacement dampers for SB 350 have smaller diameters, beginning from 6".
Logically, a smaller damper should be lighter and give the engine a higher acceleration rate. But what about its efficiency ? Is it as good as a bigger damper ?
What harmonic balancer diameter do you have guys on your SB ?
Old Jan 13, 2009 | 03:22 PM
540 RAT's Avatar
540 RAT
The larger the diameter, the more effective the damper is, all other things being equal. Unless you are a Pro Racer, you'd be better served with the largest diameter that will fit properly.
Old Jan 14, 2009 | 12:14 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
cardo0
Old Jan 14, 2009 | 01:34 AM
vettebuyer6369's Avatar
vettebuyer6369
I have a thread going on this as well, but its more of a "correctness" question. Does it matter which 8" damper you use?
Old Jan 14, 2009 | 04:39 AM
73StreetRace
If your engine is going to "see" more than 6000-6500 RPM, yes it matters.
A SFI 18.1 damper is highly recommanded in this case. But it seems to be difficult to find a 8" SFI 18.1 compliant damper.
Most of them are smaller. And here we go again !
Old Jan 14, 2009 | 08:39 AM
gkull's Avatar
gkull
Stock H.P. dampers like the GM one on L-82's are actually rated as good for dampening in a lower rpm motor.
I use all SFI 6 1/4 one motor has a FluidDamper and the other an ATI.
My original l-82 broke it's rubber ring before 50K miles. My shift kitted small block just tore it up and they are dangerous.
To Damper diameter...
