ECM question
Old Jan 13, 2009 | 04:46 PM
v8s10Dan's Avatar
v8s10Dan
Default ECM question
I am running a speed density system with the 1227730 ecm, if I replace it is it year specific or will I just need the one that is the same number 1227730
Old Jan 13, 2009 | 05:17 PM
mrvette's Avatar
mrvette
Same number, out of any car is fine, just keep your original calpak from the one you have....
If you looking for one, I have several....
Old Jan 13, 2009 | 07:58 PM
v8s10Dan's Avatar
v8s10Dan
Well I think I am,I had two injectors I think were stuck on and flooded my cylinders and was told to check my fuel pump relay with a test light and the key on and the light should come on for a minute if it did not it would mean the injectors are bad or the ecm was bad It ran fine untill I had to replace the flexplate because of I think the hydrolock from the injectors, so I ordered new injectors and thought I might as well change the ecm too, any advice on this issue? and what are you asking for a ecm?
To ECM question
