Will not go across my lap.The shoulder portion retracts and will come out,but can't get the lap portion out/seems is only as long as it is.Is there something I'm over looking or need a new (longer?) belt?
Yeah,it's a '74.........so there IS a retractor assy. down there near/under the seat,hugh?It's been like this since I got it....just working out alot of "bugs",and this is next on the list.
This is what you will find. Take time to remove all bolts and re-install with anti-seize.
The retractor can be lubed with WD40 and metal polish will clean up the brightwork.
A little Krylon finishes the job.
The belt should be outboard of the guide bar!! Fixed after photo.
And you're good for another 34 years!
I have a 75 and noticed that when I was recarpeting, there wasn't a "retractor cover" on the driver side. There was only one on the passenger side. Is this correct on a 1975 vette? or should both sides have this cover? Thanks.
