Help wiring dual spals
Old Jan 14, 2009 | 07:02 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Help wiring dual spals
I've had this dual spal setup in the C3 for about three years. Cools the stroker just GREAT! But there's a nagging issue that came up last summer and I am determined to fix now... Unless the AC is on, the fans will drop out, letting the engine get hot. Click the AC on and then of course they kick in and she cools just fine.
I got the schematic that I wired them with, on this forum but I dont' still have it. Here's what I can tell you without disassembling it all: There's three relays. One I marked AC so I know what that one does. There's one intake manifold sensor. I tried replacing that but got the same result
So the project for now is to rewire them and I need a schematic. Perhaps one relay instead of the three? It would be so simple to do that and I may just try it out. I don't know if one of my relays is bad or not; I just now swapped out the one that's NOT for the AC switching. I got the same results.
When I ground the sensor, the fans come on just fine. But after a minute or so they shut right back off.
Cannot afford an expensive controller but I can certainly wire up relays if I can get some ideas. HELP anyone? It kills me that these things worked fine for about two years before this started.
Old Jan 14, 2009 | 08:00 PM
GDaina's Avatar
GDaina
I wired mine to the solenoid with a relay per fan...but I don't have A/C
Old Jan 14, 2009 | 08:34 PM
mrvette's Avatar
mrvette
I would Google the Dual Spal fans certainly Spal has a schematic on their site for relay controls....
or go to Tom DeWitts site, certainly he would have something there, if not he can email it to you , I hope....
much faster to just d/load one than any possible description....
Old Jan 14, 2009 | 09:13 PM
Gordonm's Avatar
Gordonm
PM me your email. I have the wiring instructions and diagrams. You do need all 3 relays according to this. There is a specific way to wire them also that is different than I originally thought.
Old Jan 14, 2009 | 09:26 PM
Gordonm's Avatar
Gordonm
In case anyone else needs them here they are.
Old Jan 15, 2009 | 08:16 AM
RunningMan373's Avatar
RunningMan373
Check your engine to frame thick ground cable for loosness.
Old Jan 15, 2009 | 08:24 AM
jnb5101's Avatar
jnb5101
there was a post some time ago concerning the voltage build-up when the relays open while the car is moving, causing the fans to "free wheel". they'll act like a generator and cause an arc that might damage the relays. it was suggested that a diode be placed across the relay contact to ground this voltage spike.
Old Jan 15, 2009 | 08:29 AM
pws69's Avatar
pws69
It sounds like you have the AC relay wired in SERIES with the Enable line [for the two fan relays] instead of PARALLEL.
I would suggest you remove the AC relay from the circuit completely and get the system working with the NON AC wiring diagram. Once that is running, just connect a wire from the output of the AC relay to the ENABLE pin of the fan relays.
Old Jan 15, 2009 | 11:56 AM
SanDiegoPaul
No, they are parallel. I am going to look at it again this afternoon.
Old Jan 15, 2009 | 11:57 AM
SanDiegoPaul
I remember looking at the diagram that's on the side of the relays that came with the unit, yesterday when I was under the hood. I was comparing relays to swap them out for trial run.
The relays that came with the unit did indeed, show a diode in the diagram ... I was wondering why it was there. Thanks for that.
Old Jan 15, 2009 | 01:32 PM
mrvette's Avatar
mrvette
IF the relays had a diode across the coil, it was there to protect any possible computer/other SState device that switched the coil/relay.....
as for the fans in free wheeling mode, I seriously doubt they ever generate more than 12 volts or so to be fed back into the system, have to be doing some serious MPH to do that....
the most likely thing is the fans of course draw almost no power from the car as the onrushing air relieves the fan loading, a free no load motor conditioin makes the motor draw maybe 1/2 a amp if that....
To Help wiring dual spals
