360 spring and sport shocks installed
i did most of the work myself. my friend helped me with one shock and removing the old spring. ride hight looks good to me.. im to lazy to take the car cover off so ill just show you guys the goodies.. didnt see a heat shield with my spring so i just wrapped my pipes, im going to paint the warp black later. still gotta cut the metal straps but i left my tools back in SJ... overall the set up is nice!
Jonny78
ill post some pics tonight or 2morro
its well worth it!
I had 1" of clearance between the end of the spring and the sidewall of my tire and destroyed an almost new Goodyear Gatorback while autocrossing. I noticed a slight rub mark on the inside of the tires after a few autocrosses but thought nothing of it. But in the middle of one particularly tight turn the sidewall was ripped completely out of one of the tires.
You can also replace the rubber spacer between the spring and rear housing with a thin piece of phenolic material and lower the car some more without lowering the ends of the springs further. Here's a picture of various pieces I found on ebay for sale.
The spacer is supposed to isolate the spring from the heat of the rear. This phenolic material has all of the insulating properties and strength of the spacer and can be considerably thinner. I replaced my 1" spacer (insulator) with a 1/4" piece of phenolic and lowered the car another 3/4" without lowering the ends of the spring.
Good luck... GUSTO
I'm going to do a little cleanup and painting before I put mine on. Have you driven it yet? Hows it feel?
