carburetor help needed
Old Jan 17, 2009 | 10:22 AM
Lotadoh's Avatar
Lotadoh
Default carburetor help needed
Does anyone know of a website that has Rochester Quadrajet specifications listed as far as cfm, etc? I have a 72 with the 200 hp base engine and auto trans. It looks like the original carburetor was a 7042202 but the one on it now is a 7040208 from a 1970 GM truck. I wonder if performance wise, I should look for the original carb or am I doing better with the one from a truck? Any help would be appreciated.Thanks
Steve
Old Jan 17, 2009 | 10:33 AM
CCrane65's Avatar
CCrane65
Steve
If you do a search on Rochester carburetors you will find lots of web sites with information about the various versions.
Just guessing but a truck carburetor would have been engineered for a completely different type of usage than a Corvette so I would think you'd be better off with the original carburetor or at least one from a car with a similar engine like Camaro or Chevelle.
By the same token, you can take the one you have and have it built to the original specifications, i.e. same jets, needle and seat etc.
cc
Old Jan 17, 2009 | 01:40 PM
a1sensei's Avatar
a1sensei
All Quadrajets are 750 or 800 cfm, plenty for your car. Don't go find the original rod/ jet combo for your car and put them in the truck carb, it does not work that way. The carb you have now is probably fine as is, but if you want to fine tune it to your engine, e-mail Lars at v8fastcars@msn.com and ask for his Quadrajet tuning paper.
God bless, Sensei
Old Jan 17, 2009 | 09:16 PM
KevinZ's Avatar
KevinZ
God bless, Sensei
The truck carb being a federal emmissions and your car being a 72, may not be more than tail pipe differences.
here is a link... http://74.125.47.132/search?q=cache:...lnk&cd=4&gl=us
If it runs good, but you are looking for performance increase, Lars is the man!!!!!
Old Jan 18, 2009 | 09:12 AM
Lotadoh's Avatar
Lotadoh
ok Thanks alot for all the info. The carb runs fine. Maybe I'll just stick with it. No sense in changing something that isn't broke.
To carburetor help needed
