Next weekends 327/350 build pics...
Below is some pics of the future build and specs.
327 #678 dated block punched .30
KB 11 to 1 pistons
Stock rods
Steel crank
Voodoo cam kit with fuel injection specs. (Forward thinking if gas goes up to $4 again)
65 double hump head with 1.94/1.50. Might punch those out. I like these because of the lack of acc. holes.
Comp roller rockers
Single gear timing chain.
This is just going to be a drive motor, that will hold up to some heavy rev'ing.
Just thought I would share some pics.
68 replacement block.
[IMG]
[/IMG]KB157 pistons
[IMG]
[/IMG]Steel crank
[IMG]
[/IMG]A shot of the block with the cleaned up heads. They still need to be rebuild.
[IMG]
[/IMG]I will definely post assembly pics and break end videos as it progresses.
The only thing I've seen that was tougher on valve guides is a Ford truck. I've seen guides worn so bad a 30k miles they wouldn't idle.
I would assume he will replace the guides and valves since they are original.
Where did u get that crank Bud? Is it the stock piece? Large journal?
cardo0
JB cook in the 70s had a 10,000 sq ft machine shop two crankshaft
grinding machines they only used one crank machine the other one
was used in the 60s when they had so much work they had two shifts rebuilding engines.
My guess would have been 50 to 75k on it.
Another good thing the older blocks have is plenty of metal to over bore. I would expect 0.090" overbore is easy and not surprised if u can bore it and 1/8th".
I have to drop an name here for head work. They did a great job on my WP Torquers and pocket ported them for only 100 bucks. Great work, great prices and they love restoration Chevy heads. They don't use a w/s. Give Jim a call: Performance Chevy Products (602) 254-9586 Address: 2995 W
Whitton Ave, Phoenix, AZ 85017
Good luck Budman,
cardo0
The main bearings had only about a 20% polished surface on them and looked real good. Will replace the bearings, valve guides and rings but probably nothing else. May have to look into the bronze guides as well as mentioned above.
shmoky
