79 won't start
Old Jan 18, 2009 | 01:24 PM
emccomas's Avatar
emccomas
Default 79 won't start
OK, I finally got back to working on my 79 Vette. It won't start.
I measured the voltage at the pink wire coming into the distributor. 12 volts with the key in the on position, drops to 8 volts when the engine is spinning.
Check the test light pattern at the tach terminal on the distributor. Starts out with a bright flashing light, then changes to a steady dim light after 1 second of engine spinning.
I had the ignition module tested at the parts store. Checked out OK. I have it installed with plenty of dielectric grease.
Truly puzzled.
What is going on here?
Old Jan 18, 2009 | 02:04 PM
midyearvette's Avatar
midyearvette
check for spark at the plug wire ends and also the coil wire , all you need is air, fire and fuel......
Old Jan 18, 2009 | 03:20 PM
emccomas's Avatar
emccomas
No spark at the plug wires, tried that first.
Old Jan 18, 2009 | 03:25 PM
my 76 ray's Avatar
my 76 ray
Bad coil?
Old Jan 18, 2009 | 05:41 PM
emccomas's Avatar
emccomas
Originally Posted by my 76 ray
Bad coil?
Tried 3 coils, including a brand new one. The concensus seems to be that I need 12 volts while starting. 8 volts ain't gonna cut it. I'll wire the BAT terminal on the distributor directly to the battery and see what happens.
To 79 won't start
