Strange Race Pump fuel issue
http://www.racepumps.com/index.html
hose is a #8 line and brand new, but someomne told me that there was some more rubber suppply hose in the back going over the tank and that maybe the extreme capabilities of the pump is causing that rubber line to collapse by sucking all the air from the tank???? maybe....
Mike and Yellow, I was looking for answers on why something was not working not to be told I was wasting money to fuel my engine, but thanks for your opinion.
And yes this engine will be north of 700hp+ (with NOS) so no, I will not use a stock pump.
I finally emailed Lars, he said the problem is with todays blended fuels. Basically the alcohol lowers the boiling point to where once everything warms up the fuel will vapor lock in the line going to the pump. This problem is made worse by a high performance mechanical pump, since it pulls harder, creating more vaccum in the supply line. Since putting any liquid under a vacuum lowers the boiling point, this causes the fuel to boil. I think I made my problem worse in two ways by running a large 3/8 return line. First I believe by constantly returning a large amount of fuel from the hot engine compartment I was raising the temperature of the fuel in the gas tank. Second I connected the 3/8 return line to a existing fitting on the top left side of the tank, by returning a large amount of fuel from the top of tank I believe the fuel was becoming aerated since it have to fall about six inches into a half full tank.
Lars answer was to either add a small pusher pump at the tank to keep the whole system under a slight pressure therefore raising the boiling point of the fuel or go to electric pump, which I am in the process of doing. From reading some of this other articles on fuel systems it appears that he recommends a orfice in the feul return line between .020 and .060.
Hope this solves both of our problems.
Unless anyone else has ideas I guess it was not all it was cracked up to be
Holley blue, red or black? I was thinking black?
it did look promissing.
100% I just removed the canister and left the line there..but never had a smell of gas.
Yes there is a check vlv in line between tank and canister. But ya know what Murphy says. Yep, mine became a flow loop and gas continued to pour out the canister vent - right next to my hot header pipes and again yes it was 100*F that day.
Kinda like a gas shipon it wouldn't stop flowing untill i popped the gas cap. This also caused fuel mixed with carcoal to be feed into intake below the carb on the EVC vent line.
Well since that i replaced that little check vlv. Another story is that when i replaced my fuel tank that check vlv was not availible so i had to go with the original.
I already had replaced the original canister before filling it with gas and now have a replacement canister ready as this reminds me to swap the secound new canister in (while i have my splash guard out).Regardless i still preach using a recirc line for any mechanical pump - using a orifice restriction of course.
Keeps the fuel in line cool enough for any weather and fuel pressure stays constant at idle or WOT. If u vent the tank right at the cap - like most of us - u will be fine (to switch to vented cap only requires a vented cap). If u still vent through the EVC becareful not to top off and make shure your check vlv is in good working order. Yes venting without the orifice restriction will make tremendous amounts of vapor inside the tank from the high return line flow rate.:bbcardo0
I'm not a fan at all of the Racepumps. Looks neat.....but there are way more people that seem to have issues than anyone with anything else seems to have.
JIM
