carb & rpm
Old Jan 20, 2009 | 05:12 PM
joenome's Avatar
joenome
7th Gear
Default carb & rpm
with my 79 vette it doesn't really start to really pull until i hit 4000rpmi talked to a guy in the local speed shop and he said to try liter springs in the vacumnopener for the secondry,s does this sound right
Old Jan 20, 2009 | 07:00 PM
hugie82's Avatar
hugie82
What do you have in your engine??? Cam, Holley carb. ect...
Old Jan 21, 2009 | 10:10 AM
joenome's Avatar
joenome
7th Gear
i have a600 holley i just put on a couple of months ago and supposedly it has a mild cam put in it before i bought car
Old Jan 21, 2009 | 11:58 AM
73StreetRace's Avatar
73StreetRace
I think you should check your timing first...
You should have about 36 degrees ( initial + mechanical ), all in at 2800-3000 RPM.
If you are more than +/- 2 or 3 degrees from these values, or if you get it at too high RPM ( too late ) it could explain this kind of problem...
What kind of intake manifold do you have ?
Old Jan 21, 2009 | 02:26 PM
midyearvette's Avatar
midyearvette
Old Jan 21, 2009 | 02:57 PM
Reggie Dunlop's Avatar
Reggie Dunlop
You need to provide more info in order to get anything useful back.
Engine size?
Camshaft -duration at .050 and lift?
Heads?
Compression ratio?
Trans type?
Rear gear ratio?
Carb number?
Ingition type and timing numbers?
Intake manifold?
Last tune up?
What do the plugs look like?
Manifold vacuum at idle? - this will help determine how big the cam is.
Your question is similar to asking "how much does a fat boy weigh?"
To carb & rpm
