Firewall hole plug
Old Jan 23, 2009 | 07:23 PM
Gordonm's Avatar
Gordonm
Default Firewall hole plug
I had to run a pretty good size wire harness through the firewall. I had to put in a 2 1/2 hole in the firewall. I did it right below the heater box. I need a plug for a 2 1/2 hole and the harness is about 1 to 1 1/4 diameter. What are you guys using for a plug to plug the holes. The one I have is for sheet metal and is a little to thin for the fiberglass and the glass is thicker than sheet metal.
Old Jan 23, 2009 | 07:32 PM
lvrpool32's Avatar
lvrpool32
try these
http://store.summitracing.com/egnsea...0+115&y=8&x=27
Old Jan 23, 2009 | 07:39 PM
wills670's Avatar
wills670
Have you tried lowes? They have some and when I looked the other day they seemed a whole lot thicker than what I needed.
To Firewall hole plug
