Help w/heater-defroster system
Old Jan 24, 2009 | 10:49 AM
1rino56's Avatar
1rino56
Default Help w/heater-defroster system
My 72, w/o a/c, is blowing air thru defroster vents & heat vents at all times. I have replaced the control assembly, due to broken rollers and pointer. After replacing, I also had hot air all the time, but I adjusted the heater door and cable assembly to fix this issue. Do I replace the $14.00 switch or is it a vacuum issue. My manuals say nothing about this part of the system. Thanks
Old Jan 24, 2009 | 12:06 PM
73VetteKS's Avatar
73VetteKS
I had a similar problem with my 73 that air blew out all vents, no matter where I had the control. Turned out to be one of the vacuum pods. I think I got to vacuum pod from Dr. Rebuild.
-Jim
