New engine starting differently (when cold)?
Old Jan 24, 2009 | 07:49 PM
1972warship's Avatar
1972warship
Default New engine starting differently (when cold)?
I have just recently put in a new 383, with the old style afr 190 heads. I have the same edelbrock 750 afb style carburetor as the last engine. Anyway the new engine seems to like to have the carburetor pumped 2-3 times and the throttle held open about 1/2-3/4 of the way open to start. This seems odd b/c the old engine just required a few pumps and the engine would start without the throttle partly open.
From my basic understanding that seems like the engine is flooded a little, but it does not start at all unless I pump the accelerator some.
FYI: This is when it is cold.. when it is warm it likes to have the accelerator cracked open a little. It will start without doing that, but it starts easier if I do.
Dose anyone have any ideas?
Old Jan 24, 2009 | 08:03 PM
72LS1Vette's Avatar
72LS1Vette
In my experience I have found that every car (not fuel injected, and even some of those) has its own routine for starting. Once you figure out what the engine needs you are all set. Just pass that info along to the next owner when you sell the car.
Rick B.
Old Jan 25, 2009 | 11:21 AM
BKbroiler's Avatar
BKbroiler
I am old enough to remember when brand new cars had carburetors, with no wires attached to them. The manufacturer recommended starting procedure was to push the gas pedal to the floor (to set the choke) release the pedal then step on it slightly and turn the key. Release the pedal when the engine starts. The choke would maintain proper idle speed.
Old Jan 25, 2009 | 11:40 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Your new motor requires a little more fuel than your old motor with the same carb. A bigger cam would not have as much vacumn when cranking requiring an extra pump of the throttle.
Old Jan 25, 2009 | 01:31 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
yup me too...
Old Jan 25, 2009 | 01:35 PM
InternalBleeding's Avatar
InternalBleeding
To New engine starting differently (when cold)?
