upgrage A/C
Old Jan 27, 2009 | 01:21 PM
71white's Avatar
71white
Default upgrage A/C
I went to the Hot Rod show this weekend and talked to Vintage Air. they have a complete system for about $1200. I found this upgrade thread that cost about $800 in parts. Which way is better.
"This is with regard to converting a '73 a/c car to modern a/c:
you need a #4709 Sanden Compressor ($200)
compressor brackets from alangrovecomponents.com ($90)
a '79 evaporator ($250-300) - bolts right in
orifice tube for the evaporator ($2.00)
use factory condenser
Custom Hoses from an a/c shop ($?) - haven't done that yet
Uses no "expansion valve" "
Old Jan 29, 2009 | 09:44 AM
Rotonda's Avatar
Rotonda
I believe that you need to do some additional research. Your list does not include a drier/accumulator, nor does it include the necessary controls to allow the compressor to cycle on and off. Many Corvette parts houses carry a kit to convert your current system to the later orifice tube design (I believe that these kits are made by Olde Aire). This forum contains ar least one discussion of this conversion during 2008, and a search should locate it.
Old Jan 29, 2009 | 09:55 AM
mrvette's Avatar
mrvette
The older system is better, the one with expansion valve and POA valve, which you should have in your '71, the problems have been in the past with finding a POA valve, IMO, that constant cycling of the compressor on and off is a PIA, engine speed going up and down like a yoyo at idle, is the likely result....
I have a '88 vette serp drive and of course the C4 Sanden? comp. on there with the custom hoses for 100 bux all set up and been wonderful some 10? years now.....
Old Jan 29, 2009 | 11:09 AM
71white's Avatar
71white
Lots of good information. Thanks!!
Old Jan 30, 2009 | 02:05 PM
71coupe454's Avatar
71coupe454
Whats wrong with the system 71's came with? I was planning on just replacing the drier and adding r134 fittings.. is this not the way I want to do it?
Old Jan 30, 2009 | 05:28 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I did that with my '71 454 (along with new rxpansion valve and POA valve) and it was running great for 2 years before I tore my engine apart for the rebuild.
Old Jan 30, 2009 | 09:51 PM
kaiserbud's Avatar
kaiserbud
Can ya'll specify if you used R12 or R134a?
Old Jan 30, 2009 | 10:24 PM
DC3's Avatar
DC3
I've been researching the best way to add AC to my '73. I've talked to folks and read about others who have compared older C3s and muscle cars with both the factory air and the aftermarket systems by Vintage Air or Hot Rod Air. In each case I'm told the new aftermarket systems cool better, have fewer problems, and use less HP. Now, what I don't have a clue about is whether or not the original factory systems can be modified to perform as well as the aftermarket systems. That said, I've made the decision to use one of the aftermarket systems.
DC
Old Jan 31, 2009 | 05:15 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I used R134a, the R12 was redeculously expensive. I even stayed with the stock condenser, which is not very efficient with R134a refrigerant.
Old Jan 31, 2009 | 05:20 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
DC
Thats what I was doing, I wanted to upgrade the stock C3 A/C to bring it upto the newer cars systems, but I ended paying just too much that it was better for me to get a whole aftermarket setup.
What I did basically is get a Sanden 508 with its bracket, and a parallel flow condenser and all the needed lines hoses, besides restoring the evaporator box and getting a new A/C harness/vacuum hoses. When add all that costs together, you'll notice thats just too much of pain for what I paid!.
To upgrage A/C
