T10 markings what do they mean?
Old Jan 27, 2009 | 02:59 PM
livelotus's Avatar
livelotus
Default T10 markings what do they mean?
I was looking at my 4sp and I saw "WC1 62" right under it I saw "166425229 the 5229 being the last four digits of my vin. I think this is the standard "wide ratio??" transmission. ??
Howard
by the way, it's on a 1976 coupe.
Thanks Karol.
Old Jan 27, 2009 | 09:55 PM
hicswa's Avatar
hicswa
WC1 62 . W= Borg-Warner C = March 1 = the first day, 6 = 1976. for a wide-ratio unit there would be a 1 so since yours is a two is must be a close-ratio.
Danny
Old Jan 27, 2009 | 10:31 PM
livelotus's Avatar
livelotus
Danny,
Thanks!
Howard
Old Jan 27, 2009 | 11:31 PM
20mercury's Avatar
20mercury
Default same question for my 76 4 sp
I just went down these bunny trails and one source, I think Prince, said what you described regarding close ratio and wide ratio. Another source says this is the production shift that made the 4sp and not close or wide ratio. See links below
http://fiedlerh.home.att.net/BW.htm
http://www.dandltransmission.com/borgratio.html
I finally came to the conclusion that the only way to tell was to pull the 4sp and check the grooves on the input shaft. Or if I could read my build sheet that would also be a way.
If someone has more info, I would like to hear it too.
Thanks.
Old Jan 28, 2009 | 02:22 PM
hicswa's Avatar
hicswa
Thanks.
Ah, I got my info from my Richard Prince Corvette 1968 to 1982 Restoration guide but your info on the number two stating the second shift makes more sense.
Thanks,
Danny
Sorry Howard, That is why this site is so great!
Old Jan 28, 2009 | 02:52 PM
livelotus's Avatar
livelotus
A member also sent me a few more clues. I think I have the wide ratio. If I read the info correctly it only came with the 3:36 differential, which is what I have. The input shaft has 3 grooves also. If that helps any one...
To T10 markings what do they mean?
