Squishy Brake problem
We have bled the brakes four times and even tried a Motive power bleeder. All 4 calipers are new. The problem is the brake pedal is very soft almost all the way to the floor (no pressure) and then the brakes slam on.
You have to be careful to not lock up the wheels. Took it to a mechanic and he ran 2.5 pints through it bleeding them and it still has the problem.
Someone told me that the booster might be bad or installed incorrectly, but wouldn't that mean the brake pedal would be harder to press? Anyone got any idea what is happening?
You can test the booster. With the engine off, press the brake pedal. does it get hard? It's supposed to get hard and stay hard.
Then, while pressing on the pedal, start the car. Does the pedal go soft and down? It's supposed to.
If it doesn't do either of those things you might have a booster problem but I suspect it's the master cylinder.
Something to check since it was already installed when you got the car. Maybe the guy did not install the right lenght rod.
The booster pushrod adjustment can be tricky and take time because as the car heats up the pushrod expands and if you've adjusted the screw too far out it will begin to drag the brakes. Get it hot, and adjust the pushrod so that it brings the pedal up, but still rolls freely in neutral.
Javier
it's in the booster, and in my switch to HBoost some 5? years ago I did a direct A-B comparo.....totally left the lines in the braking system alone, removed the m/cyl, and installed it on the HBoost unit, without disturbing ONE THING in the brake hydraulic hookup.....
car stopped on a dime, 9 cents change, nose into the steering wheel....and that was with air in the P/steering hydraulics on account of my having the lines open for the HB install.....
SO, after fighting these brakes for some TEN YEARS before doing the HB install.....the very first time the car had a decent pedal was when doing the HB......
and its remained fine since then.....
WHY GM brakes are all soft as sand, I dunno, must be a design goal for something to do with safety....but I like a short throw pedal with a hard as nails manual brakes feel to it...none of that squishey soft feel that makes you think there is a bananna on the brake pedal....
