Big Block Alternator
Old Jan 29, 2009 | 09:14 PM
POLY's Avatar
POLY
Default Big Block Alternator
I have a 74 with a big block 540ci Dart block motor, I am running an electric water pump and looking for a high output mini alternator around 100amp, which could be mounted as a low mount to clear the electric water pump, any suggestions would be appreciated. Thanks...
Old Jan 30, 2009 | 01:05 AM
Z-man's Avatar
Z-man
If you're not afraid of used equipment, I found tons of CS-144s (140 amp) in a junk yard.
Link
Old Jan 30, 2009 | 09:07 AM
Durango_Boy's Avatar
Durango_Boy
I agree the CS144 is a great power upgrade but it certainly isn't 'mini' in fact it's bigger than the SI cases.
However, the CS130 is the little brother to the CS144. It's a 100 amp max alternator, with 60 amps at idle which is very good. Get the right one and it's a direct swap in for your stock alternator once you change the pulley and get a different adjustment bolt for the Metric threads.
You'll need an adapter from Napa for the wiring so you have the resistance the new alternator needs, but it's a very easy swap and it's smaller than the CS144.
http://photos.imageevent.com/durango...%20Install.pdf
Old Jan 30, 2009 | 10:37 AM
POLY's Avatar
POLY
Default mini alternator
space is an issue, the stock size alt does not fit a low mount install, it hits the front frame crossmember and the block, a mini alt (smaller dia) with high amp output is needed...
Old Jan 30, 2009 | 02:35 PM
dmaaero's Avatar
dmaaero
have you seen these? I saw one on a chevelle an its tiny,
http://www.gzmotorsports.com/racing-alternators.html
Old Feb 3, 2009 | 07:00 PM
POLY's Avatar
POLY
Thanks, I'll give them a call...
Old Feb 4, 2009 | 12:33 AM
Ironcross's Avatar
Ironcross
You may not be aware of this alternator unless you have access to a parts store or service center, But there is a direct replacement 94 amp alternator available at more knowledgeable parts stores or re builders. You dont have to change a thing, bolts directly on and it actually matches the appearance of your old GM except 94 Amp Delco. Zero other parts required.
Old Feb 5, 2009 | 02:29 PM
SMH's Avatar
SMH
Here is what I used on mine.
http://www.jegs.com/i/Moroso/710/63840/10002/-1
http://www.jegs.com/i/Moroso/710/63841/10002/-1
[IMG][/IMG]
To Big Block Alternator
