Air Cleaner Doesn't Fit
Jan 31, 2009 | 09:50 PM
I bought a 14" drop down air cleaner for my 72 but the base is hitting the ignition coil. Is the coil mounted in the wrong spot or do I need a drop down offset air cleaner? The coil mounting looks a little suspect. Any help greatly appreciated.
Jan 31, 2009 | 09:51 PM
How easily would you be able to modify the coil bracket...or make your own, or move it, so the air cleaner doesn't interfere with it?
Jan 31, 2009 | 09:53 PM
Move the coil to a cooler place.
Jan 31, 2009 | 09:57 PM
I could move it. Its mounted to the intake manifold. I've heard of the air cleaner base hitting an hei distributor, but not the coil. I'm just wondering if there is an easy fix.
Feb 1, 2009 | 08:47 AM
thegazman
If you don't want to move the coil, look on ebay for an offset dropped base. I bought a new 14" dropped, offset aluminum dropped base for $15.
Feb 1, 2009 | 12:12 PM
Feb 1, 2009 | 12:45 PM
Eldelbrock makes a open air cleaner dropped. found mine at summit
Feb 2, 2009 | 07:52 PM
I had this same prob yesterday and am going to use the original base from my old one, you cant realy see it that well. just a suggestion
Feb 4, 2009 | 07:00 PM
I got it. Thanks for the suggestions. I just bent the coil bracket back a little so its slanted back. The base fit fine.
