I bought a complete rear end out of a 79 with a 3:55 gear.I plan on putting it in my 73.My 73 has a LS1 with a 4l60 transmisson and a 3;08 rear gear.What will be the difference i n rpm's ? The side yokes on the 79 rear end has U bolts and the 73 the caps.Which is the strongest? Thanks Charlie
Cap on the yokes are the "HD" type. They're the same yoke only use caps instead of U-bolts. The 78-79 diffs were not too good. I strongly suggest you look it over good before bolting it in place. They had soft yokes, poor RG bolts, & poor clutches to name a couple of things to check. The 73 diff isn't really much different, other then the yokes, RG bolts were better they used the same crappy clutches. Both can be made 1000 % better if you take the time to build them.
Good luck
