BB Idler pulley
Old Feb 6, 2009 | 12:55 PM
langg's Avatar
langg
Default BB Idler pulley
Hi Guys.
I know this topic may have been addressed before but this may be a slight variation. I have a BB in my 75. I put aluminum pulleys on the crank and water pump along with the idler set-up for the inner belt. The idler hits the pulley with about 2 inches of the adjustment slot left. A 34 5/8 inch belt is too short and a 53 1/8 inch belt is too long because the idler hits. By the way, it is a Merlin block and has P/S and A/C.
Any ideas or a pics of the idler/pulley fit?
THanks
Langg
Old Feb 6, 2009 | 01:37 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you have a custom config.
you might specifiy what aluminum pulleys.
Thats like asking how big are my wheels ?
trail and error, in the custom world.
Old Feb 6, 2009 | 02:00 PM
langg's Avatar
langg
Unfortunately, the pulleys are 'no-name' units. The water pump pulley is 6 1/2 inch diameter. I would have to either measure the crank pully in place or remove it. I am getting ready to raise the car for other work. I'll see if i can measure it then.
Langg
Old Feb 6, 2009 | 02:26 PM
Ironcross's Avatar
Ironcross
I dont know why you need a idler for the BB anyway...But since you must, Trying to adapt a given belt size to the pulleys will sometimes find problems as you experienced. Do it the other way around. When the pulleys are set, measure with another belt the idler and all pulleys related to the idler even if you have to cut it. Lay it out and tape the measurement. Then buy a belt that length....
Old Feb 6, 2009 | 02:59 PM
langg's Avatar
langg
I see there is a typo in my first post.
A 34 5/8 inch belt (p/n 7340) is too short a 35 1/8 inch belt (p/n 7345) is too long. i dont think they make a belt in between. I can't get the 34 5/8 belt on even when I remove the water pump pulley, put the belt on then try to get the pulley back on. I can't get the 35 1/8 belt to tighten even with the idler. The idler hits the pulley when it is moved in the 'tighten belt' direction.
Old Feb 6, 2009 | 03:40 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I was researching in the 71 Assembly manual a few weeks ago and I was suprised to see that on the BB cars there is a BB idler used. I thought it would be a fixed idler not a spring loaded unit.
Anyway try going to a little wider belt on the one thats too long
Old Feb 6, 2009 | 04:13 PM
langg's Avatar
langg
Wider? Interesting idea. I didn't know wider was available. I currently have a 10mm wide belt. What increments are available.
Old Feb 6, 2009 | 08:26 PM
wfo76's Avatar
wfo76
I think the idler pulley was only used on 70-74 big blocks with A/C and helped keep
the water pump pulley from slipping with the added load of the compressor.
Old Feb 6, 2009 | 09:48 PM
CCrane65's Avatar
CCrane65
That is exactly correct. You should hear the noise when you don't have the idler and crank/pump belt. The idler is necessary because there is no built-in tension adjustment between the crank and pump so the belt has to be over sized to allow for it to be installed with both pulleys in place. Then the idler is used to apply tension to the belt.
The idler is not a spring loaded unit, it is stationary with a slotted opening for tension adjustment.
cc
P.S. langg, you need to measure the original water pump pulley and crank pulley and try to find some the same size so the idler doesn't hit. Why would you swap pulleys without making sure they are the same size? Most likely the water pump pulley is all the needs replaced.
Old Feb 7, 2009 | 06:47 PM
langg's Avatar
langg
The whole engine is a 'custom' setup. The only Chevy parts are the heads and the idler which is an aftermarket repro. I can put 'original' pulleys on. Will that solve my problem? Since the 3 groove water pump pulley is so expensive, I don't want to just buy one to see.
Langg
Old Feb 7, 2009 | 06:52 PM
CCrane65's Avatar
CCrane65
Langg
The original pulleys should fix your problem.
cc
Old Feb 7, 2009 | 07:14 PM
langg's Avatar
langg
Thanks CCrane72.
Any chance you know what the pulley diameters are? My w/p pulley measures 6 1/2 OD.
Langg
Old Feb 7, 2009 | 09:19 PM
Ironcross's Avatar
Ironcross
As long as the pulleys fit and lines up why worry, use them.
Old Feb 7, 2009 | 10:10 PM
CCrane65's Avatar
CCrane65
Thanks CCrane72.
Langg
Sure don't. What you need to get is the pulleys off of a 70-72 454 that had A/C. The non-A/C engines may have the same pulleys but I know for sure the A/C ones will fit
cc
Old Feb 7, 2009 | 10:17 PM
CCrane65's Avatar
CCrane65
Read his original post. The idler pulley hits the water pump pulley so he can't apply tension on his crank to water pump belt.
cc
Old Feb 7, 2009 | 10:29 PM
CCrane65's Avatar
CCrane65
You could try what a po had put on my engine. No crank to water pump belt or idler but rather a large belt over the A/C, crank and water pump. It did not squeal but it did have enough deflection that it was wearing a groove in my lower radiator hose.
That's why I took it back to the original belt configuration.
cc
Check out my reponse in your other post if you are looking for the original configuration of the belts.
Last edited by CCrane65; Feb 8, 2009 at 03:06 PM. Reason: correction RE: pulley vs. belt
To BB Idler pulley
