Replacing Timing Chain
Old Feb 6, 2009 | 10:24 PM
82X-FireVette's Avatar
82X-FireVette
Default Replacing Timing Chain
Does anybody know if a double roller timing chain and gears will fit under the stock timing cover on a small block?
Old Feb 6, 2009 | 10:27 PM
mrvette's Avatar
mrvette
YES, the Cloys double roller will fit, and last a VERY long time too....
Old Feb 6, 2009 | 10:32 PM
1974ta's Avatar
1974ta
Cloys is the answer. Just did mine.
Old Feb 7, 2009 | 02:27 AM
RunningMan373's Avatar
RunningMan373
Before:
After:
Old Feb 7, 2009 | 04:57 AM
worship79's Avatar
worship79
Fitted CompCams Magnum Double roller without a problem.
Old Feb 7, 2009 | 09:52 AM
Paul L's Avatar
Paul L
Yes.
Old Feb 7, 2009 | 10:44 AM
682XLR8's Avatar
682XLR8
Have a Cloyes on my 383, stock cover fits fine
Old Feb 7, 2009 | 10:48 AM
1nicecorvette's Avatar
1nicecorvette
can it be changed on the car with engine installed in case the problem may arrise
Old Feb 7, 2009 | 02:09 PM
worship79's Avatar
worship79
Perhaps theoretically, but practically i don't think so.
Old Feb 7, 2009 | 02:21 PM
Paul L's Avatar
Paul L
I'm afraid that I have to disagree.
Old Feb 7, 2009 | 02:28 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Timing set replacement is easy. Make sure you have the proper tools, especially the damper puller and installer. Just a bunch of nuts and bolts. And your engine will love you for it. Cloyes double roller is a top notch piece. A stock engine can get by with a good single non-roller. But the Cloyes is certainly a nice piece...
Old Feb 8, 2009 | 04:00 AM
worship79's Avatar
worship79
Why be afraid, it's not a crime to disagree But since not all of us are a contortionist... You just removed fan, waterpump, radiator and shroud and had enough room to handle a puller? Did you work from above the engine or did you use a bridge?
Old Feb 8, 2009 | 06:01 AM
RunningMan373
No need to remove the radiator or fan shroud. You can work from above the engine, but on some of the more difficult or repetative uses of the puller, I had to ballance on my stomache on the fender. use a blanket if you like your paint. More then possible,, it's done.
Old Feb 8, 2009 | 07:51 AM
Paul L's Avatar
Paul L
The car was on jackstands so work was done from above and below. We replaced rear main seal, oil pump, FelPro oil pan gasket, front seal, Cloyes timing set, rad hoses, waterpump, and all drive belts. One of those "while-you're-at-it" Saturdays.
Old Feb 8, 2009 | 08:21 AM
worship79's Avatar
worship79
Impressive... perhaps time for me to take some yoga lessons
Old Feb 8, 2009 | 09:58 AM
Paul Workman's Avatar
Paul Workman
Love those one-piece pan gaskets! They really eliminate one of the more serious PIAs of the SBC.
P.
Old Feb 8, 2009 | 04:48 PM
bluedawg's Avatar
bluedawg
shouldn't a gear drive fit under the cover too? and now that i know about the one piece pan gaskets is there a way to convert to a one piece rear main on the original blocks?
Old Feb 10, 2009 | 07:22 PM
82X-FireVette
Thanks for your replies. Looks like I'm gettin' a Cloyes double roller setup.
Paul 74 I'm doin' the same as you plus rebuilding the upper control arms and steering box.
To Replacing Timing Chain
