LM 1 A/F Sensor Question
Old Feb 9, 2009 | 06:06 PM
Bud2's Avatar
Bud2
Bud2
Default LM 1 A/F Sensor Question
Any of you guys use this item? I'm just starting to learn how to use the LM 1 a/f sensor on my 350 sb, 64 vette. Was going to wire the RPM signal from the coil to the LMA 2 RPM converter. The directions said to simply "wire it to the 'keyed' side of the coil". What does that mean? Do you simply take an insulated wire and connect to coil then to the correct inlet on the LMA 2? No ground or anything???
I've used the 'clamp' on the spark plug wire to get the signal at the moment but may want to install the a/f sensor permanently later.
Thanks in Advance
Bud.
Old Feb 9, 2009 | 08:37 PM
Gordonm's Avatar
Gordonm
I wired mine directly to the tach signal wire from my Crane HI6 box. The LM1 is a great tuning tool and I got mine spot on with this.
