Steering curiosity question
Old Feb 12, 2009 | 06:11 PM
bytor's Avatar
bytor
Default Steering curiosity question
I recently replaced a leaky power steering control valve on my vette. I was talking to a buddy of mine who has a 78 Chevy Caprice and asked him if he ever had to change one. He said he didn’t have one that his steering gear box connected directly to his power steering pump. He doesn’t have a control valve or power steering cylinder. So my question is, why didn’t GM use the ‘all in one’ type steering gear box on the vettes?
Old Feb 12, 2009 | 06:29 PM
GTR1999's Avatar
GTR1999
Jim Shea can probably best answer that question. I can tell you the vette box is unique to corvette.
Old Feb 12, 2009 | 06:49 PM
kansas123's Avatar
kansas123
Seems I have heard somewhere that the control valve was unique to Corvettes.
Old Feb 12, 2009 | 08:10 PM
mrvette's Avatar
mrvette
Not likely, since a buddy has one on his Mercruiser outdrive for steering assist......supposedly this vette system predates the dinosaurs and was used on trucks in Hitlers' army....
Old Feb 12, 2009 | 08:20 PM
Sayfoo's Avatar
Sayfoo
I believe it was a space issue. Not much room under the hood.
Not sure when this type of ps became obsolete, but it was used on alot of cars. I had a 69 mustang with this type.
Old Feb 12, 2009 | 08:21 PM
PeteZO6's Avatar
PeteZO6
I thought it was because the integral Saginaw p/s box was too large physically to fit into the C2/3 chassis. Since then newer smaller boxes like the so-called Jeep unit will fit, but came along too late for our cars.
If I'm mistaken, Jim will straighten me out.
Cheers,
Pete
Old Feb 12, 2009 | 08:23 PM
Ironcross's Avatar
Ironcross
Default Nope, Ford
Except that is only correct if you discount the thousands that Ford put on the streets....see your driving a Ford in disguise....
A 1 Cardone rebuilds most of those sold through the States and probably Canada too. Any Parts store
Vampyre's Avatar
Vampyre
Cheers,
Pete
I believe the above is correct, but this one rocks and I will now use that as my standard answer..
Old Feb 12, 2009 | 08:51 PM
Ironcross's Avatar
Ironcross
Ford started using control valves on there mid-sized and smaller {Mustang} since 1964. Stopped when FWD`s took over...and rack and pinion was used
Old Feb 12, 2009 | 11:05 PM
wombvette's Avatar
wombvette
The Corvette system gives more road feel and feed back than the newer type. It is shared with other GM cars like Chevy II. This system gives you variable assist. If you are going real slow or sitting still, there is lots of resistance to a turn of the wheel. This makes the control ball in the valve move more and increases flow and pressure to the assist cylinder. If you are going fast there is less pressure applied and there is little assist. Feel and control, is the reason for the continued use of the old style system.
Old Feb 12, 2009 | 11:41 PM
RHD '68 L89's Avatar
RHD '68 L89
From my knowledge, which may be flawed, the PAS system was used on Full size chevys 62-64. Corvette used it from the 63 model year and continued until the C4.
Holden also used the same valve body from 66 to 71.
I believe it was part of the trade off that Zora made for the independant rear end. He had to use standard parts bin items for the front end. The control arms are full size 64 parts, but turned around to get the geometry he wanted.
Old Feb 13, 2009 | 07:29 AM
Jim Shea's Avatar
Jim Shea
Around 1967 Saginaw tried to convince Chevrolet engineering to use their integral power steering gear instead of the control valve and adapter with booster cylinder. Although the 1968 Vette appeared all new, the chassis basically carried over. There was extensive frame and front crossmember modifications that were required to adapt a Saginaw integral power gear. Also the gear itself required a special housing casting to fit the Corvette frame.
There was one 1967/68 Corvette that was modified at Saginaw with an integral power gear and sent to Chevrolet engineering. The word was that the Chevrolet engineers were not impressed. Extensive frame modifications needed to adapt the gear didn't help either.
There was at least one privately modified 1968 Vette that now resides in Florida with a special integral power gear. That Vette also has a T&T steering column which wasn't available until 1969.
I don't know about the original decision to use the valve and adapter type power assist. The Chevelle came out in 1964 with the Saginaw integral power gear. The big Impala came out with the integral gear in 1965.
Jim
Old Feb 13, 2009 | 07:45 AM
bytor's Avatar
bytor
Thanks for all the feedback. Good discussion!
Old Feb 13, 2009 | 12:43 PM
Solid LT1's Avatar
Solid LT1
Our power steering system was invented by Bendix in the 1950's look under any Mustang with power steering buit before 1971 and you will see a familiar system.
To Steering curiosity question
