Freon required for early 76 (larger compressor)
Old Feb 12, 2009 | 10:37 PM
reddog76's Avatar
reddog76
Default Freon required for early 76 (larger compressor)
Anyone know how much R-12 needed for early 76 (larger compressor) air conditioning? I still have 3 cans left but don't know if it is enough. Have to replace the line to the compressor. It hisses at me when it is bumped. Still some freon in system but almost done (will be when dis-assembled).
Reddog76
Old Feb 12, 2009 | 10:45 PM
71coupe454's Avatar
71coupe454
around 3 lbs would be my guess, should be on the sticker. or search for "capacities" it would be a good time to change over to r134a but if your 3 cans will do it, might as well use it
Old Feb 12, 2009 | 11:56 PM
pkolis's Avatar
pkolis
Cruising
Don't forget to add oil, see your service manual for how much. R12 is colder, but a lot more expensive.
Old Feb 13, 2009 | 12:39 AM
BOBCAT1's Avatar
BOBCAT1
Where is your leak? I had same problem with my 76. A service bulletin was issued that year titled "HEATER HOSE CLAMP INTERFERENCE WITH A/C EVAPORATOR INLET PIPE". That caused my problem-rubbed hole in my pipe. You can Google it and see the bulletin along w/a drawing.
Old Feb 13, 2009 | 11:50 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Your 3 cans will be enough. System usually takes about 2lbs7oz + oil.
When adding freon run engine at approx1800rpm & add till sight glass runs clear. SInce you have the old A6 compressor be forwarned the front seal of the compressor is probably leaking as well.
When system is evacuated replace the front seal.
If there s still a charge present your have local A/C serice shop draw down your system(recycle the freon).
Usually for a small fee they will recover your freon, note the amount drawn out. Then when repairs are done they will "give you back" your freon.
May cost the normal service fee. I've done this for many customers over the years
To Freon required for early 76 (larger compressor)
