I just put a new tach circuit board in my 75 this past weekend and zero'd it per the instructions that came with the circuit board. I put the dash back in and turned the key on and the tach needle was below 0. Is this OK or should I pull it back out and redo it?
Tim...I'm curious. Had you buttoned the dash back or up or just enough to test the tach?
I just did this on my 76 and it took a couple of episodes to get the tach pointer set right. I also checked the zero point and cross checked the reading at 1000 to 2000rpm with a separate meter. Mine from Mid America was off 100-200rpm on one side or the other, so I split the difference on the needle placement.
I suggest you might want to crank it and get the tach pointer like you want it with the instr panel not installed and resting on something to avoid multible instr panel installations. On the other hand after a lot of practice, I got to where I could install the instrument panel pretty quick!
Good luck!
There is no need to split hairs here. On the board is a potentiometer (We calibrate ours before we send them out) that can be used to adjust the tach reading. You can dial this thing in to be dead on!
In the picture below it’s located in the left hand upper corner. You can adjust the calibration of each tach by turning this. It will damper or increase the signal to the tach board.
Tim:
If you zero the board out and install the needle, test it again to make sure. If the needle still fails to go to zero I’m afraid you may have a problem with the internal part of the tach. You should always power up the tach before installing it back in the dash to make sure it zeros out and just as a safety measure you might want to hard wire it before installing to test it.
Much thanks for the info, this is really good to know.
Originally Posted by Willcox Corvette
20 Merc.
Tim:
Thanks to all for the help. I pulled the tach back out and removed it from the dash panel, plugged it up to the tach wires and removed the needle. Cut the ignition on and put the needle back on at zero. I cut the ignition off and moved the needle by hand, cut the ignition back on and the needle went to zero.
