Good Distributor guy to change gear??
Old Feb 13, 2009 | 01:37 PM
newcastlegreg's Avatar
newcastlegreg
Default Good Distributor guy to change gear??
You guys convinced me on the pro billet tach drive. Now I need to find a good distributor guy to install a steel melonized gear for the new crate zz454. Aparrently the shaft or gear has to be re-machined. Can you reccomend someone who is familier with this??
Greg
Old Feb 13, 2009 | 03:04 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Changing the gear is easy. Just drive the pin out and swap gears and drive the pin back in. Takes about a minute. As for the size, once you get the melonized gear and your new distributor you can see how much it needs to be machined. I just took my gear to a machine shop and they turned it to the size of the shaft (slightly over sized). My research showed that various distributor manufacturers use different shaft sizes so you will need to have both in hand before you know which way you need to go. Any machine shop with a lathe will be able to do the work you don't need a dist. specialist.
Old Feb 13, 2009 | 04:07 PM
Little Mouse's Avatar
Little Mouse
You need a .500 ID gear for the MSD.
PN-8572 Corvette pro-billet tach drive comes with # 8531 gear,
# 8433 cap, # 8467 rotor.
MSD shows to have a .500 melonized iron gear # 8561 around $55.00 call MSD if needed. www.msdignition.com
Tech phone line 915-855-7123.
www.summitracing.com
To Good Distributor guy to change gear??
