How much will heads raise comp ratio?
Old Feb 13, 2009 | 05:13 PM
Lester B's Avatar
Lester B
Default How much will heads raise comp ratio?
Hi people,
I have a 77 L82 and am thinking about fitting a set of Edlebrock Performer RPM heads.
Correct me if Im wrong, my standard heads are 76cc with a standard compression of 9.5:1 (or is it 9.0:1)
The heads I will be looking to fit are 64cc.
Any ideas on how much the comp ratio will raise with the 12cc difference?
Thanks In Advance,
Lester
Old Feb 13, 2009 | 05:34 PM
Oldguard 7's Avatar
Oldguard 7
Your engine uses the same camshaft (L46) 350/350. i I think the pistons are the same as the 350/300 engine. Your heads will increase it to about 10.00:1. I have the Edel RPM 64cc heads and the same flat-top pistons as the L-82 as well as the aforementioned cam. Others will correct me if i'm wrong.
Old Feb 13, 2009 | 07:49 PM
Little Mouse's Avatar
Little Mouse
bore 4.00
stroke 3.48
head cc 76
valve notchs cc 6cc
head gasket .018
piston down .026
Compression 8.87
bore 4.00
stroke 3.48
head cc 64
valve notch 6 cc
head gasket .018
piston down .026
Compression 10.06
.018 is what I have seen listed for factory steel shim gaskets.
anyway you should see a little over a point comp.
Old Feb 14, 2009 | 02:40 AM
Lester B's Avatar
Lester B
Thanks for that guys, didnt want to go much above 10:1 so its all good. One day I might eventually gain the knowledge to work it out myself
Thanks again
Lester
To How much will heads raise comp ratio?
