Damn radiator! &%$#@&%!!!!!
I removed the 6 bolts on the sides, even the 2 on the bottom of the support, this thing will not come out.
I can move it around, back and forth, even slightly side to side, but up is totally out of the question. I even got a large screwdriver (padded side) and tried to pry it out of the mount, to no avail.
What's the secret?
Please?
It's been a while since I worked on mine, but I do remember that it's impossible to get the radiator out without pulling the shroud first.
The shroud is a PITA in it's own rite too.
The easiest way I found to get the shroud in and out is to unbolt the passenger side upper upper A-arm and swing it back out of the way. Just make sure you keep track of shims so you can put them back the same way when you are done.
if it's the radiator:
1.remove the fanblade
2. remove the radiator/shroud brackets. pull the shroud towards the motor and hang it onto the WP pulley to keep it out of the way. it will NOT come out until the radiator is removed so don't try.
3.disconnect and unbolt the radiator (previously drained of course)
4.remove the top two bolts of the core support on each side and just loosen the lower 3rd bolt at the bottom of each side but don't remove.
4.lean the core support as forward towards the front of the car as possible until it just hits the headlight actuators. This will give you room to slide the radiator out.
5. remove the radiator. You usually have to lift it up from the drivers side first if I remember to give a little extra room for the lower hose housing to clear the A-arm but I might be mistaken and have that reversed, it might be the passenger side first. Sorry, it's 2 years since I last pulled mine.
Just doing this is enough reason to add the VBP strut bar to reduce this flexing.
I'm trying to get the radiator and shroud both out so I can get the upper A-arms out to replace them with the VBP kit.
The car is up on jackstands.
I've drained (most of) the radiator (the petcock is frozen, so all the fluid I can get out of the lower hose outlet is out).
I removed all 6 of the shroud bolts and the 2 at the bottom, I can move the whole assembly around, and I can slightly move the shroud away from the radiator, but not far enough to get either one of them to slide up.
I've tried to pull both together, tried to pull the shroud first, and tried to pull the radiator first.
On previous cars, I just cut the shroud in half, but I don't want to do that with this one knowing that someone else may need this, so I'm trying to limit the damage I'm causing.
It seems that it's all so tight in there, and it has to come in/out in a specific order, and right now I'm not sure what that order is. Of course, it doesn't help that I'm working by myself either.
Thanks for the help so far, I'll keep checking this for more words of wisdom from you all!
you can NOT get the shroud out until AFTER the radiator is out, it just ain't gonna happen.
remove the fan and move the shroud back to the motor out of the way. unbolt and tilt the core support forward. this gives you the room you need to lift the radiator out.
Unless you are forgetting a bolt somewhere it will come out - ut may take some finessing to get the lower hose housing past the A-arm but it will come out.
Since you are changing the front suspension anyway go ahead and unbolt both upper A-arms. You don't even need to disconnect the upper ball joints yet, just removed the two nuts that connect the cross shafts to the frame, then lightly knock the bolts through with a hammer. Then the A-arms can just be swung backwards out of the way. It will give you just enough room to get the shroud out through the top, then once the shroud is out of the way the radiator will come out too.
I had to replace the fan shroud on my 73 when I first got it because the previous owner had cut it in half, and the lower half was missing.
Four years ago when I built and installed the 383 I also replaced the radiator and core support in it too. The procedure I described above is the only way I could find get the fan out (or into) my 73.
Good luck.
I can't pull the shroud backward, away from the radiator enough to maneuver either one of them separately. The radiator is kept in place by the lower outlet getting caught on the shroud, the shroud is caught by the upper inlet and both forward A-arm bolts.
I've tried pushing both of them together from underneath even, but it doesn't budge. It's like there is something else holding everything down that I can't see. I've tried prying the rad away from the lower u-shaped mounts, no joy there either.
Oh, and no cooling lines either, I have a manual transmission!
(but you're right, sometimes the simple stuff gets you!)This is sooooo fr'king frustrating!!!!!!!!!!!!!!!!!!!!!
If you have AC it helps tremendously to unbolt the compressor and move it back out of the way too.
Takes pics of the progression of your bloody knuckles for us.
I just removed my radiator and had it recored.
This is what I had to do to finally get it out.
Remove the hood.
Remove the radiator hold down brackets.
Remove all the bolts that hold the support surround.
Cut the support rod that goes from the bottom of the surround to the nose of the car. Clearly - that rod was put there only to annoy us - you don't need it!
Now slide the radiator and the support surround forward and that will give you the clearance you need to raise the radiator out.
Now you can easily lift out the surround and give it a coat of paint.
Re assembly is easy once you bite the bullet and take all of that stuff off.
The main problem was that the radiator was literally 'stuck' from the seals between the shroud and the rad.
Anybody have a good lead on new seals??
I guess they come as a set, eh?Oh well, it's out, the front suspension is finally all out, the steering is almost out (need to get the PS lines off the pump, get the steering box off, and figure out how to get the pitman arm off the steering box.)
I'm planning on going this route: http://www.corvettesteering.com/corvemt4.jpg
from Tom's Steering. Anybody else have this box? Any recommendations, one way or the other? I was thinking about the Steeroids kit, but Tom's is half the price, and less fabrication I think.
At any rate, thanks for the inputs folks! I appreciate the extra "ooomph" you gave me to get this done!
Anybody know if DeWitt's is going to have another sale anytime soon?
