Hello, I recently re-did my center gauges and put in new bulbs, white gauges, etc. I also replaced the clock. After hooking up the center console wiring to the gauge cluster the lights all work again, and the clock finally works again!
However, when I turn the ignition switch to the ON position, the GEN light does not come on. As I recall it DID come ON in the past. Is this correct? Any ideas. Did I screw something up?
Thanks.
Reason: changed title to something more relevant
I think I found part of the problem. The fuse was blown. When I replaced it, it blew again. So I must have a short. Is it possible that one of those little copper contacts on the back of the gauge cluster could be shorting against another? They are a biatch and a half to connect.
