Gmpp 454 ho
Old Feb 14, 2009 | 10:56 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Default Gmpp 454 ho
Greetings all,
I am considering swapping out the SB for the 454 HO in my 73 coupe. What technical difficulties am I looking at?
Will the OEM water pump fit? Will my cowl hood clear the OEM instake with a Holley and decent air cleaner? I found some hooker headers which look like they will work, and I have new exhaust otherwise. What else will I need in the way of brackets pulleys etc? Anybody done this one?
thanks in advance, peace out.
Old Feb 14, 2009 | 11:02 PM
DVNTST8's Avatar
DVNTST8
From: if you have a ? on my avatar, please contact me directly, you spineless twit
St. Jude Donor '09
You'll need different springs on the front end, IIRC.
Old Feb 14, 2009 | 11:22 PM
71coupe454's Avatar
71coupe454
I went though some hassel with missing pulleys and brackets on my 71. That crap adds up quick! Not sure but I dont think much of your small block stuff is gonna work. Maybe finding a donor engine with all that stuff in tact would be the best way? I would encourage the change over but let all these guys in here tell you the most painless way.. maybe a newer donor car with serp belt system?
Old Feb 15, 2009 | 10:37 AM
CheezMoe's Avatar
CheezMoe
Figured I'd give this a bump since I posted it late. I'm hoping maybe I can use stock brackets and pulleys for 73 454. My big concerns are intake/hood and valve cover/ brake booster clearances.
Thanks again in advance.
Old Feb 15, 2009 | 10:51 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Alot of little things that add up fast.
Hoses, some wiring, fittings, pulleys / brackets / belts, exhaust re-done, fluids, the list goes on.
I decided not to go BB and built / installed a SB 406, it's lighter so no front spring change and cheaper to make HP. (parts) It RW hp on dyno at 477hp @ 5200 rpm.
Good luck with your swap.
Old Feb 15, 2009 | 10:55 AM
Glass Act's Avatar
Glass Act
73 could be ordered with a BB so clearances will not be an issue.
Old Feb 15, 2009 | 12:47 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Stock brackets will work form a BB, Intakes that will fit have been discussed here many times I don't have the list, might try a search here. The factory short valve covers will clear the brake booster, tall covers wont. Keep in mind that our cars vary and every once in a while someone gets lucky and parts fit that don't normally. BB headers are a good example they fit fine on some and on others they have to be massaged to fit.
Old Feb 15, 2009 | 10:33 PM
bstbrgr's Avatar
bstbrgr
Just go to Billet, they sell all the brackets for the swap. I will not look original but will have a polished dressed up look to it. I also have a 454 LS-7 GM crate motor for sale, but it's more of a high perf motor. Not for you if you plan to drive your car a lot.
Old Feb 16, 2009 | 12:09 PM
CheezMoe's Avatar
CheezMoe
I will indeed check out the Billet stuff. Thanks for the offer on the LS-7 but I need a little more street friendly than that.
Old Feb 16, 2009 | 04:50 PM
Ironcross's Avatar
Ironcross
you will need a new flywheel
To Gmpp 454 ho
