Anyone do a rack and pinion conversion
Old Feb 16, 2009 | 08:50 PM
Dabikerus's Avatar
Dabikerus
1st Gear
Default Anyone do a rack and pinion conversion
I am considering the rack and pinion unit in the Mid America catalog. Has anyone installed one of these? Good or bad?
Old Feb 16, 2009 | 08:53 PM
mrvette's Avatar
mrvette
Do your own, junkyard parts, a bit of creativity and a welding buddy to make it solid....it's easy, really....
Old Feb 16, 2009 | 11:28 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Yep, best mod ever.
Details for the do it yourselfer...
http://www.corvetteforum.net/c3/427v8/
Old Feb 17, 2009 | 12:23 AM
MN-Brent's Avatar
MN-Brent
Steeroids kit and the VBP Rack Attack kit are what your talking about.
I fully recommend them. You may have to clearance your frame at the rack input pinion to clear the locking set screw. I hit it with a 4inch angle grinder.
I also recommend you replace your steering column lower bearing so the is ZERO end play in your column shaft.
Setting the double U-joint is easy if you FULLY seat the lower U-joint on the rack pinion and stretch the upper U-joint as far up the column as possible.
Those are the gotchas and other than that, you'll love the feel.
Brent.
To Anyone do a rack and pinion conversion
