Trans Cooler By Pass Radiator
Old Feb 18, 2009 | 07:51 PM
VictoriaVette's Avatar
VictoriaVette
Default Trans Cooler By Pass Radiator
Has anyone used a trans cooler and by passed the radiator? I was told the trans would run cooler it I did not run the trans fluid through the radiator and only through a external cooler. What is your thoughts on this any proof one way or the other?
Old Feb 18, 2009 | 07:55 PM
cargo247's Avatar
cargo247
I by passed mine and the rad is not for really cooling its for heating the oil for cold weather.
Todd
Old Feb 18, 2009 | 08:01 PM
VictoriaVette
How big of cooler did you use and have you had any problems? Do you use a fan? tell me about your set up engine/trans etc
Old Feb 18, 2009 | 08:22 PM
71coupe454's Avatar
71coupe454
My un-informed thinking would be that the external cooler is designed to provide additional cooling, not designed to be the only cooling. Maybe if it was a good sized one, but then you are blocking your radiator more.
Old Feb 18, 2009 | 08:24 PM
cargo247's Avatar
cargo247
i Cant remember the size the cooler but it just fits nicely in front of the rad, i pulled the lines out of the rad and plugged the rad holes then cut the lines and attached high pressure hydraulic hose to the fittings on the cooler with gear clamps works great. 350 and stock auto trans
Todd
Old Feb 18, 2009 | 08:26 PM
cargo247's Avatar
cargo247
well how well do you cool when your running though a hot rad?
Old Feb 18, 2009 | 08:31 PM
VictoriaVette
I was told that if a radiator runs at 195 degrees that the trans fluid never get below that and if you by pas the radiator and just use a cooler the trans runs cooler. the size o the cooler in the radiator is smaller than an external cool would be anyhow.
Old Feb 18, 2009 | 09:10 PM
cargo247's Avatar
cargo247
the cooler in the rad is flat like a pancake and about 10" long and 2" wide not much for cooling.
Whats is the enemy of oil? .....heat....brakes it down.
keep it cool man
Todd
Old Feb 18, 2009 | 09:15 PM
VictoriaVette
Thats what I was thinking and then already up to engine temp and mine is 180 to 200 degrees I think a external cooler would work better also.
Old Feb 18, 2009 | 09:17 PM
cargo247's Avatar
cargo247
good luck
Todd
Old Feb 18, 2009 | 09:29 PM
71coupe454's Avatar
71coupe454
What temp does a trans run?
Old Feb 18, 2009 | 09:39 PM
VictoriaVette
I have no idea and would like to know myself maybe someone will post it.
Old Feb 18, 2009 | 09:49 PM
71coupe454's Avatar
71coupe454
one place I found says... "optimum operating range of 160°F to 200°F"
hmmm my t-stat is right in the middle of that
Old Feb 18, 2009 | 09:57 PM
VictoriaVette
Thanks for that info so I would do better with an external cooler I would think. My 77 runs from 180 to 200 degrees. And if I put a higher stall it would create more heat. I just wonder if the engine temp would fall with out the trans running through the radiator.
Old Feb 18, 2009 | 10:08 PM
Theiskell's Avatar
Theiskell
Running a transmission too cold is just as bad as running it too hot. The cooler lines run through the radiator to help warm the fluid when cold as well as cool it when hot. Typically your tranny will run about 20-30 degrees cooler than you engine temps. It’s good to run the line through a cooler first, but then it’s best to go through the radiator before it returns back to the tranny. This will keep the transmission in it’s optimal operating range.
Old Feb 18, 2009 | 10:13 PM
cargo247's Avatar
cargo247
read this
http://www.tciauto.com/Products/Tech...expectancy.asp
Old Feb 18, 2009 | 10:16 PM
VictoriaVette
That makes since to me but why do you say to cool is not good?
To Trans Cooler By Pass Radiator
Old Feb 18, 2009 | 10:41 PM
Theiskell's Avatar
Theiskell
Too cool will cause clutches to slip more, causing premature wear. Check out BTO (Bow tie Overdrives) website, there is lots of good information there on this subject.
PS. I’m not saying a cooler isn’t a good idea (I run one) Just plum it correctly for the best performance.
Old Feb 18, 2009 | 10:48 PM
VictoriaVette
Thanks I'm going to get a trans temp gauge to keep a good look at it and know where I should be. I see 175 to 225 is the best temp for them. Thanks for all you info that is what I'm a member here for.
Old Feb 18, 2009 | 10:55 PM
Theiskell's Avatar
Theiskell
To me that states what we know “Heat Kills Transmissions” it says the optimum range is 175 – 225 and what happens above those temperatures. Since a preferred range is noted there must be a reason to heat it up to 175..
Edit>>> i should note that BTO wants their trannys to run in the 150 range.I know its cooler than what this website specified, but I thought it was worth mentioning.
