sb engine rebuild
Edelbrock Performer Intake mainifold EDE 2101
Edelbrock Performer Cam EDE 7102 and lifters
Holley 600
+30 Overbores
Before I put it back together again, could anyone tell me if these parts are suitable? I could still put back the standard cam and original manifold.
Regards,
Barry.
All SB 350 parts can fit a SB 350 but not all will work for your needs.
If you have a stock 350 hood I think that is the largest manifold that Edelbrock recomends that will clear is the performer. I put an air gap in my 69 vert but my air cleaner rubs so I am going to change the hood. Once I do that I am going with a bigger intake.
As for the cam you picked it is matched for the Performer RPM manifold which might be too tall for your engine bay.
Also this cam is rated for a RPM RANGE of 1500-6500
Duration at 0.006" Lift: Intake: 308° Exhaust: 318°
Duration at 0.050" Lift: Intake: 234° Exhaust: 244°
Lift at Cam: Intake: 0.325" Exhaust: 0.340"
Lift at Valve: Intake: 0.488" Exhaust: 0.510"
Timing at 0.050" lift: Open Close
Intake: 10° BTDC 44° ABDC
Exhaust: 59° BBDC 5° ATDC
Centerlines: Lobe Separation - 112° Intake Centerline - 107°
Like I said, tell us what you want from your engine and what you want to spend and we can help you spend that money.
even so, you still haven't really provided enough info. are the heads stock? what's the valve sizes? you already said .030 over, but are they flat top, dome or dished pistons? any idea what the SCR is? that would be a start.
I changed the Rochester for the Holley 600. I might have adjusted the valve clearances incorrectly when tightening the pushrods. I feel the car has never run well and it takes 15 minutes before it idles properly.
The fuel consumption is only about 10 mpg, and in the UK that's very expensive! I've got a mechanic friend coming round on Sunday so I'll give him the tech details which you sent. My main concern is whether to put back the old cam, but if you have any other suggestions I'd be glad to hear them.
Regards,
Barry.
Thanks Barry
Regards,
Barry
Thanks Barry
Good luck!
Regards,
Barry
But since I have a 383 it is lumpy but can be daily driven.
Like I said I have a performer air gap in my 69 and it just clears now. I tried an RPM Air Gap but it really rubbed. To find out where the air cleaner rubbed I put play doh all around my air cleaner, closed the hood, then started the engine and reved it up. When I stopped the engine and lifted the hood it showed where the air cleaner rubbed. It rubbed on the front right and when I reved it up it rubbed more to the front. So to fix this I did not use any gaskets from the carb to the base plate and then I lowered the front of the baseplate 1/3 inch more (bent it). I put it all back together and there is no rubbing now.
I forgot to ask if you have an auto or manual trans? I have a turbo 400 and run a B&M Holeshot 2400 which works great at the track and on the street, but if you also have an auto your stock stall conv will be to low. I get 8MPG on average as I have a heavy foot and gas was up to $1.55/litre Cdn for 91 octane
In my original stock 350 with all stock except the cam, I run a Comp Cam Xtreme Energy™ XE268H and it is nice. It sits in my brothers garage right now as I have no space for it.
Good luck!
Good luck!
