are hooker sidepipes right for me
Old Feb 20, 2009 | 05:52 PM
captl27's Avatar
captl27
Default are hooker sidepipes right for me
I am building an 470 horse small block 400. I am thinking of putting 1 3/4 hooker headers with sidepipes with the small block 2 1/2 to 4 mufflers. Any body out there have any input.
Old Feb 20, 2009 | 06:27 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Small block primaries on the sidepipe headers are 1 7/8" not sure but I think that is the only size
Old Feb 20, 2009 | 09:16 PM
captl27's Avatar
captl27
i was just looking on summit and i thought i found hooker headers sidepipes with 1 3/4 primary tubes. I thought they would be better for me then 1 7/8s but I went back and checked and i was wrong there was only 1 7/8. is that too much primary for my engine/
Old Feb 21, 2009 | 01:22 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Keep in mind that the extra length of the sidemount primaries (46") somewhat offsets the effects of larger diameter. If you're looking to precisely locate peak torque you may need to contact someone like Stahl, but the Hookers work out for a good many of us. As it is, the BB version (2.125" x 45" primaries) projects to put my next 427's peak right where I want it, but I doubt I'd go with any other pipes anyway.
TSW
Old Feb 21, 2009 | 07:11 PM
captl27's Avatar
captl27
so the long primaries make the differance. Is there a place that I can see the numbers
Old Feb 21, 2009 | 08:59 PM
TheSkunkWorks
Here's a primer on how headers effect torque as good as any you'll likely find short of an engineering text. I've seen other more complex formula for deducing theoretical peak torque RPM in which velocity isn't a fixed value nor many variables assumed/dismissed, but the basic equation illustrated within this article should suffice for all but the most precision of work.
http://www.carcraft.com/techarticles...ics/index.html
More difficult than estimating the peak torque RPM is to quantify how the body of the curve is effected above and below the peak torque RPM by primary volume. As this requires a plethora of variables be taken into account, IMHO one is better off getting Desktop Dyno or better (read, "expensive") simulation software rather than daring to attempt such with pencil and paper.
TSW
edit - Just to note, I ran the CarCraft formula on my 427 combo and found it varied somewhat high from results yielded thru Engine Analyzer Pro sims. There are more involved formula I've played with a bit that were pretty close to EA Pro's projections, and I'll post up if I find one of them that's readily translated.
Old Feb 21, 2009 | 10:33 PM
captl27's Avatar
captl27
so you (the article) is telling me that normally the 1 7/8 primary is big for my engine but since the primary tube is extra long this make the hooker header more compatable with my engine.
Old Feb 21, 2009 | 10:48 PM
TheSkunkWorks
Basically, bigger diameter primaries mean higher peak torque RPM, but longer primaries mean more area under the torque curve below the peak and less above it. Consider diameter as more or less the fulcrum of the torque curve and the length as tipping the curve one way or the other on that fulcrum.
Old Feb 21, 2009 | 11:07 PM
captl27's Avatar
captl27
Thanks for the help I have been reading some of the other threads and most guys that have them seem to say they work for them or at least they did not do any harm.
Old Feb 22, 2009 | 10:18 AM
SteveG75's Avatar
SteveG75
I am using them on a 355. If you want the Hooker sidepipes, then 1-7/8 is your only choice. Life is full of tradeoffs.
Old Feb 23, 2009 | 03:48 PM
captl27's Avatar
captl27
are you happy with them on your 355
Old Feb 23, 2009 | 06:30 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
They look right, they sound right, they perform very well, what's not to like? Im using them with Max Flow inserts on my 500 HP 383.
Check here:
http://forums.corvetteforum.com/c3-t...-carlisle.html
Old Feb 23, 2009 | 06:54 PM
SteveG75's Avatar
SteveG75
I like them a lot. I don't have a back to back comparison since I had the motor rebuilt and swapped to a slightly smaller roller cam when I installed the sidepipes.
Car still pulls hard, can smoke them off the line (3.27 first in the Tremec), and sounds great with STS baffles. Honestly, I can cruise with the radio on and they are not even too loud unless I floor it.
I just see them as an excuse to build a bigger motor. Decision is just whether I go for a budget (realtively) 383 build or a 400 based on the new Dart block. Decisions, decisions.
Old Feb 24, 2009 | 02:16 PM
captl27's Avatar
captl27
when you say sts baffles are you talking spiral turbo baffles?
Old Feb 24, 2009 | 05:41 PM
blckslvr79's Avatar
blckslvr79
Old Feb 24, 2009 | 06:58 PM
captl27's Avatar
captl27
Thanks for the help. I will be buying hooker sidepipes for my 79
Old Feb 24, 2009 | 07:19 PM
TheSkunkWorks
A decision you shouldn't regret.
To are hooker sidepipes right for me
