shock install question
Old Feb 21, 2009 | 08:15 PM
baxsom's Avatar
baxsom
Default shock install question
i put new shocks front and rear on my 72 today.
nothing super hard core but basic oem replacement.
i was using my haynes manual.
it said to let the front hang free but the rear wheels needed some preload on the spring before i unbolted the shock.
i didnt have a problem changing them out but i was just wondering why the rear needed to have preload on the spring while the front was ok to hang free.
Old Feb 21, 2009 | 09:03 PM
72LS1Vette's Avatar
72LS1Vette
There is some play in the rear shock mounts. If you don't jack up the trailing arms to ~ride height the shock mount can tilt downwards a bit and it won't align correctly with the shock.
Rick B.
Old Feb 21, 2009 | 09:11 PM
JimT's Avatar
JimT
When I replaced my shocks, it was much easier to install the rears when I lifted the trailing arms.
Old Feb 21, 2009 | 10:14 PM
baxsom's Avatar
baxsom
i see, probably explains why i got them in easily. i did what the manual says. imagine that.
To shock install question
