fuel pump bolt torque
Old Feb 21, 2009 | 11:42 PM
willem wallace's Avatar
willem wallace
Default fuel pump bolt torque
Could someone give me the correct bolt torques for the 3/8" mechanical fuel pump bolts, and the 1/4" pump plate bolts.
Thanks!
Old Feb 22, 2009 | 12:49 AM
19LEW71's Avatar
19LEW71
Thanks!
according to 1971 aim
pump bolts at 25-30 lbs
plate bolts at 32-40 lbs
Old Feb 22, 2009 | 02:02 PM
willem wallace
Default torques
Thanks 19Lew,
I saw those values in the AIM. Was trying to see if anyone else had another source. I am a rookie, but the torque assigned to the 1/4" bolts seems like it may be a misprint.
Old Feb 22, 2009 | 02:04 PM
midyearvette's Avatar
midyearvette
Thanks 19Lew,
doNOT try 32-40 foot lbs. on a 1/4 " bolt.........probably inch pounds
Old Feb 23, 2009 | 12:12 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
I have snapped those bolts off before. The little 1/4-20 bolt heads will twist right off. Quick google check says 65-72 in-lbs ('bout 6 ft-lbs).
Good luck,
cardo0
To fuel pump bolt torque
