when I decelerate from any speed really but you can really tell the faster you are going the rear end seems to move sideways and you have to correct it in the steering. was wandering if anybody had any ideas?
thanks
There's a lot of things that can cause that... and none of them are something to ignore.
Suspension mounts loose or broken, diff side yokes excess play, wheel bearings faulty/worn, trailing arm bushes worn... or worse, trailing arm mount or chassis rusted...
just a few things to consider.... but get under there and find what it is.
