1-will the orignal backup switch & bracket simply bolt on and plug in (and then work ) on my 69. It now has a Richmond 5 speed installed.
2-I have a neutral safety switch on my clutch, I have discovered two Purple wires in the harness near the e-brake. I am assuming these are for an automatics neutral switch (?) If thats the case should put in a jump wire and close the circuit.
the two purple wires by the e brake can be ignored. they are in parallel with the wires by the clutch. if you jumper them, you will defeat the clutch switch.
