forced induction in my c3 (need advice)
350 bored 60 over
forged speed pro internals
.495 lift cam
9.5-1 compression
i'm stopped right now im tryin to do research on this setup and apparantly not a lot of people do it
should i run a supercharger or good ol turbo(s)
i want to stay with the forced induction set up
any advice would be nice thank you
now, im only 21
so im still learning too
for now, im keepin myself busy with replacing some gaskets on the egnine, restoring/modding exterior/interior in my 79, no time to be wondering how to fit a turbo under the hood.
It sounds like you have pretty decent lift on the cam, but what cam is it?
I thought turbocharged setups were run in the 7:1 range in terms of compression, static, before the induction charge is factored in?
It sounds like you have a decent built bottom end for a reliable 350, although the .060 overbore doesn't make me feel totally comfortable. Make sure your cooling system is sorted out properly if you're running that much overbore.
It appears you have a lot to do on the project aside from the motor. My advice to you, is go with what you've got, but throw on a budget set of heads L-31 Vortecs, with matching intake, a simple carb setup, and get the thing running. Once you're on the road, you'll come up with a long list of things that need addressing.
Then, once the car is sorted out and you run out of projects, save up a budget to go forced induction (which might require a different bottom end setup, whether dishes in the pistons, or otherwise large volume cylinder heads, to get you into the right compression zone). But this way, you won't be left guessing when there's a problem, because the car will be otherwise reliable.
I bought my 69 coupe at the age of 20 as well, and I'm 10 years into the project now, still going strong. But believe me, it took about 6 years to get to the point where I was actually happy and confident with anything I was doing.
This forum is a good resource, and I also recommend www.hotrodders.com for general tech troubleshooting.
Good luck, brother.
the blonde weasel
just pick a set of budget cast iron heads that work for your bottom end setup. slap a 600 or 650 cfm carb on there and get it running, then go from there.
cheers
engine will fit under hood without air filter,but i would not run like that,the hilborn scoop works really good ,forces cold air down the engine and runs unbelieveable .I also have 9 to1.people that have never had forced induction dont know the awsome power they put out ,excitement everytime you drive the car.i have had my engine built 4 times over the years with more hp everytime,and when i went to a blower that was it,i will always have all my vehicles supercharged,i have a truck that is supercharged with a paxton novi 2000,with nitrous.Heres a pic of a 177 weiand blower engine that i built for a friend.
forgive me for the ford,sorry guys,its a sweet truck.
best turbo book ive read is Maximum Boost by Corky Bell. as far as tuning, after getting everything installed correctly, rent a dolly from u-haul and tow it to the nearest dyno shop. Im eyeing up a twin turbo setup and thats going to be my approach. also, i decided to go with fuel injection to make tuning easier. im prob about to be crucified for saying that, but im 26 and have worked on FI cars my whole life, tried to rebuild my quadrajet and the motor never ran right since (so bad it could barely idle). bought a full TPI setup, some bigger injectors (for my 383) and how she runs relatively well. just sayin that carbs apparently arent my forte. but thats just my opinion/direction/setup. best of luck to you. when you get to buyin parts, post some pics of the build!
I see a blower in this car's future as well.. only because it has the cheap mexican 4 bolt goodwrench block in it pushing a whopping 7.8:1 ratio as it sits right now..
However,It is not rocket science but needs to be researched and understood before diving in.There are advantages and disadvantages to each one of them,so a lot of research goes a long way on the discision process.
i really appreciate all the advice guys beings i already have the motor built the way it is im just going to finish the motor out and put 150 wet kit there paint it gloss black and put ccw's (maybe) lol on it i have an s10 that i been tinkering with i guess ill make that my racing vehicle again thanks for all the advice and my dad doesnt really know much about chevrolets as it is (mopar man) he believes that if it dont have a 440 or 426 in it it aint fast... which i cant argue with him lol
