Torq Thrusts On A 74
Old Feb 27, 2009 | 03:29 PM
C3HOONIGAN's Avatar
C3HOONIGAN
Default Torq Thrusts On A 74
I want to put Torq Thrusts on my 74, but dont know what backspacing i need. I was thinking a 17 inch rim but anyone have any advice or pics of cars with them?
Old Feb 27, 2009 | 04:21 PM
1hotrod's Avatar
1hotrod
17x8 with 4.5 backspacing if I remember correctly.
Old Feb 27, 2009 | 04:52 PM
SteveG75's Avatar
SteveG75
4" backspacing on 17x8 will put wheels in same location as stock.
Old Feb 27, 2009 | 04:55 PM
Kevins77's Avatar
Kevins77
I dont know the backspacing off the top of my head... sorry..
Here are a couple of pics of my 74 with the Torq Thrust II's:
Old Feb 27, 2009 | 05:54 PM
C3HOONIGAN's Avatar
C3HOONIGAN
This might be kind of a long shot but would anyone maybe be able to tell me what the sizes are on this vette....i pretty much want mine turning out to look like this.
thanks!
Old Feb 27, 2009 | 06:38 PM
yellow-fever's Avatar
yellow-fever
Those are prolly 17's but could be 18's. The problem is that the tires are too short and therefore there is too much wheel well showing around them. Whatever tires you use, they need to be as close as possible to 27 inches tall. A 255/50/17 is perfect.
Old Feb 27, 2009 | 06:56 PM
C3HOONIGAN's Avatar
C3HOONIGAN
Any guess on backspacing on that red one?
Old Feb 27, 2009 | 08:03 PM
PRATASEIS's Avatar
PRATASEIS
Product Number: 5057861
Product Description:
17X8 TORQ-THRUST II 5X4.75
Fully polished
Backside Spacing (in/mm):4/102
Offset: -11.43 mm
Old Feb 27, 2009 | 08:23 PM
C3HOONIGAN's Avatar
C3HOONIGAN
Not to be annoying but, your sure about that? haha sorry
Old Feb 27, 2009 | 08:34 PM
C3HOONIGAN's Avatar
C3HOONIGAN
tire size? 255/70/17 like yellow fever said?
Old Feb 27, 2009 | 08:42 PM
3JsVette's Avatar
3JsVette
A couple of things you may want to give some thought to. Do you want to run the same size on all 4 corners or do you want a staggered fit (wider in the rear)? As stated above if you want the same on all 4 corners 17x8 with 4" backspace. A 255/50 tire is the same height as the stock tire. There have been a lot stories lately about American Racing building their wheels "off shore" and due to this there have been long delays with "custom" backspace as well as quality issues. With that in mind you may want to consider Vintage Wheel Works. http://www.vintagewheelworks.com/products/wheels They are a bit more money but as they say quality wise "you get what you pay for". Go luck with what ever you choose to do.
Old Feb 27, 2009 | 08:57 PM
C3HOONIGAN's Avatar
C3HOONIGAN
From what i can see in the picture of the red one, it looks like they're running a staggered fit, thats what i would want to do...so just go for a wider rim in the rear? Any ideas on what width?
Old Feb 27, 2009 | 10:57 PM
yellow-fever
No, 255/50/17, not 255/70/17. I have custom grey center 15x8 Torq Thrust II's with 4" backspacing (-13 mm offset) and 255/60/15 BFG's all around on my 74 and the tires were VERY close to the e-brake cables on the rear trailing arms before I relocated them. For this reason, I would NOT go with MORE than 4" backspacing. Put the extra width on the outside of the rim if you go wider than 8".
Old Feb 27, 2009 | 11:32 PM
3JsVette's Avatar
3JsVette
Do a search on "18s" in this forum. There is lots of reading. Here this will get you started http://forums.corvetteforum.com/c3-t...-required.html
As you will soon realize all these cars are a little different. Some cars get 5.5" backspace to work with NO MODS others don't. This is a chance you take if you decide to go with 18x10s or even 18x9.5 in the rear.
Old Mar 1, 2009 | 12:40 PM
elle88's Avatar
elle88
I still don't understand totally the matter of the backspacing.
do this rim clear the brake caliper or not?
http://www.vintagewheelworks.com/pro...heels/v45/15x8
thanks
Old Mar 1, 2009 | 02:24 PM
71rdster's Avatar
71rdster
thanks
You need more specs on that wheel to know for sure. I am only guessing here, but my guess is that that wheel is intended for Camaros and TA's in the GM bolt pattern. Their disk rotor's and calipers are far more compact than a C3 Vette's. So I am guessing that they won't fit a C3 Vette.
Old Mar 1, 2009 | 03:14 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
<-------- 17" Coys C5's with 255/50R17
To Torq Thrusts On A 74
Old Mar 1, 2009 | 03:35 PM
Gordonm's Avatar
Gordonm
17X8 4 inch backspace front with 255 45 17.
18X10 5.5 inch backspace rear with 275 40 18s
Stock trailing arms, ebrake cable relocated, no sway bar and rear spring shortened 1/2 inch both sides
Old Mar 1, 2009 | 09:39 PM
1996Z15's Avatar
1996Z15
Would love to see a view from the rear to get an idea of how massive the tires look and how well they fit. I've seen your car a few times at Kerbeck's Toys For Tots runs but, never noticed the width of the tires.
Old Mar 1, 2009 | 10:12 PM
Gordonm's Avatar
Gordonm
Here you go. No exhaust on the car but this is the only one I have of the rear.
