1978 theft relay battery drain
Old Feb 28, 2009 | 09:36 AM
jknb1205's Avatar
jknb1205
6th Gear
Default 1978 theft relay battery drain
I have tracked a battery drain to the anti theft relay located in the center console, the relay is draining the equivilent of the glove box light not sure on exact amps, but the two were equivilent. Is my problem as simple as replacing the relay? Is the relay capable of pulling a drain on the battery. Any help would be appreciated.
Thanks,
Jim
Old Mar 12, 2009 | 07:32 PM
y2kvett's Avatar
y2kvett
Default Anti-theft battery drain
99.99% of the time this relay is turned on because the anti-theft horn is not working or missing and system is turned-on. To turn it off, just put your key in the drivers door and unlock the door lock. This turns a switch in the door which turns the system off. Then check your drain and find the horn in the rear driver side quarter panel (up where you can't reach it with the muffler in place). You can leave the relay out if you like.
Old Mar 12, 2009 | 10:33 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
but on the 78 the horn is in the driver side front inner fender well, kinda under the brake booster.
If you listen closely, can you hear the flasher clicking?
Old Mar 12, 2009 | 11:55 PM
y2kvett's Avatar
y2kvett
Default must have moved in '78
The 77 had it in the rear fender area. I guess that '78 was the year they moved the horn.
Old Mar 22, 2009 | 11:11 AM
MNTWINS33's Avatar
MNTWINS33
So you are saying the horn is not in the steering wheel?
Old Mar 22, 2009 | 12:14 PM
wfo76's Avatar
wfo76
Not sure about 78, but the earlier C3 alarms had a separate horn just for the alarm mounted behind the driver side rear fender.
The alarm horn relay was in the jack tool box at the very bottom.
Old Mar 22, 2009 | 02:40 PM
wer2xu's Avatar
wer2xu
there is no horn in any steering wheel.
The ALARM horn, is either above the driver muffler, or inside the driver side fender.
The traffic horn is between the headlights, operated by a button in the center of the steering wheel.
To 1978 theft relay battery drain
