Tilt/tele column repair
Old Feb 28, 2009 | 05:31 PM
Dave Witman's Avatar
Dave Witman
Default Tilt/tele column repair
I have dissassembled my 73 steering column to repair worn tilt pins. Before i started job I noticed that the lower bearing had slid out and down column. I also noticed that the shift tube does not appear to be up into the shaft far enough to install lower bearing into its correct location. I need to either remove shift tube and inspect or just try to install tube farther into shaft. Having problems moving tube in either direction and of coruse proper tool is not made any more. Any help please.Dave
Old Feb 28, 2009 | 05:58 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Some of should self-correct when you put the base bolts back in You will have access to them after you extract the tilt pins..
Old Feb 28, 2009 | 06:20 PM
Dave Witman
The problem still exists with the base bolts tight. Dave
Old Feb 28, 2009 | 08:27 PM
Daffy's Avatar
Daffy
Is it possible that the lower collar is not locked into the shift tube...That would keep it from going into place..Just a shot in the dark..
Old Feb 28, 2009 | 10:15 PM
Dave Witman
Not sure what you mean. Dave
To Tilt/tele column repair
