1971 Alternator Bracket
Old Feb 28, 2009 | 07:19 PM
RBRUTLEDGE's Avatar
RBRUTLEDGE
Default 1971 Alternator Bracket
I have a 1971 and it came with the "F" type 2 piece bracket. What a piece of junk. The alternator twists when I tension the belt an squeels most of the time. I also do not like how it bolts to the header bolts. The "F" Bracket ended up breaking. I have tried Ecklers, Mid-America, Summit, Jegs, Zip, and Corvette America for a replacement and they all seem to say the "F" type is for 1968 and earlier. The ones for the 1971 do not look anything like I would expect to fit Does anyone have any ideas or pictures, or brand names you have had success with? Any help would be greatly appreciated!
Old Feb 28, 2009 | 09:12 PM
682XLR8's Avatar
682XLR8
I think this bracket is from a 71. This the one you saw on the vendors site? I went with this on my 68 because I was tired of the POS F-bracket flexing when the engine was running
[IMG][/IMG]
[IMG][/IMG]
Old Mar 1, 2009 | 02:10 AM
Carl Granquist's Avatar
Carl Granquist
Default Alt Brac
Here's mine. An older set of Hedman headers but it's the correct bracket. Mine were slightly out of alignment causing unneccessary wear on the alternator. Phillips Automotive near Redmond, WA made the adjustment for me. Knew it was wrong when he first looked at it. Something about headers on the sb350. Several brackets will bolt on but only one is correct for fitment, depending. Good luck!
Old Mar 1, 2009 | 06:08 PM
RBRUTLEDGE's Avatar
RBRUTLEDGE
thanks guys, i think i did see one like these on a vendors site. the f-bracket just isn't working!
Old Mar 1, 2009 | 09:32 PM
jackson's Avatar
jackson
perhaps in some years base 350 got stamped bracket while performance 350 got the other one?
To 1971 Alternator Bracket
