71 engine wiring diagram HELP
Old Mar 1, 2009 | 08:30 AM
HunterPayne's Avatar
HunterPayne
Default 71 engine wiring diagram HELP
Hello everyone,
My assembly manual has been driving me crazy tracking down the TCS system. I found this article from NCRS RMC that the assembly manual is WRONG!!!!
http://www.ncrsrmc.org/Downloads/Mar...Newsletter.pdf
They have the corrected diagram from the May 1971 Chevrolet Service News, but I can't see the damn thing in the pdf file.
Would anyone know where to get the correct diagram???
Thanks,
Hunter
Old Mar 1, 2009 | 10:12 AM
SIXFOOTER's Avatar
SIXFOOTER
what do you mean "I can't see it"?
If you can't open the document all you need to do is download Adobe Reader. If you mean the document isn't clear I might be able to help. I have software to crack a PDF and I may be able to pull out the pieces you need.
Old Mar 1, 2009 | 10:14 AM
HunterPayne
Sorry about that. I can see the document but the diagram scan is so poor in the document that I can't see the detail in the schematic
Old Mar 1, 2009 | 10:24 AM
SIXFOOTER's Avatar
SIXFOOTER
gotcha, I'll see if I can peel that piece out and clean it up. It is pretty bad
Old Mar 1, 2009 | 10:37 AM
SIXFOOTER's Avatar
SIXFOOTER
Hmmm, that didn't work. The drawing in the newsletter came out as an all black square.
I'll keep futsing with it
Old Mar 1, 2009 | 10:42 AM
wer2xu's Avatar
wer2xu
I just zoomed into 300% and every things is clear...
Old Mar 2, 2009 | 09:59 PM
Carl Granquist's Avatar
Carl Granquist
Default Diagram graphics
For me "zooming in" just makes the detail worse, not better. Do these two attachments help any?
I believe my electrical diagram to be accurate, but if you find a '71 engine wiring diagram that has been "corrected" could you please post it for all of us '71 owners to share?
File Type: pdf
File Type: pdf
Old Mar 3, 2009 | 10:24 AM
HunterPayne
Thank you. These seem to be the same as in my assembly manual. I had no luck trying to clean up what they had in the NCRS newsletter. I will email them and see if I can get a copy to post
Old Mar 3, 2009 | 10:35 AM
HunterPayne
This brings up another question......does a 71 base motor 350 have a TCS temp switch in the passenger side head or does it feed off the temp switch on the drivers side?
Old Mar 3, 2009 | 10:37 AM
cargo247's Avatar
cargo247
is this what your looking for
http://www.lbfun.com/warehouse/tech_...tte%201971.pdf
Todd
Old Mar 3, 2009 | 11:34 AM
HunterPayne
yes, that looks like the one. Thank you very much
Old Mar 3, 2009 | 01:04 PM
theandies's Avatar
theandies
Do what I did, take your AIM, copy the wiring diagram pages. You'll notice an ajoining page legend on the bottom of each page. Match up the pages and cut them to fit. Tape the whole thing together and wala, you have a huge wiring diagram.
To 71 engine wiring diagram HELP
