Auto meter or Dolphin Gauges on 77?
Old Mar 1, 2009 | 09:22 AM
dmeesq's Avatar
dmeesq
Default Auto meter or Dolphin Gauges on 77?
I was thinking about replacing the stock center cluster gauges on my 77 with either Auto Meter or Dolphin Gauges, does anyone know if I can use the existing senders and wiring or do I have to replace them with the ones that come with the gauges?
Old Mar 1, 2009 | 12:49 PM
fauxrs2's Avatar
fauxrs2
I've never heard of Dolphin gauges before but the Autometers i installed used the factory senders just fine. Both temp and fuel level. I replced the electric oil pressure gauge with a mechanical gauge so I cannot speak to that particular sender.
Wiring you will have to fashion yourself to a certain extent, especially if your center cluster uses the circuit board type of connections like my 78 did. However you can wire directly to the connector that plugs into the back of the cluster.
My gauge install
Old Mar 1, 2009 | 02:19 PM
neuroclast's Avatar
neuroclast
Wow I just wanted to say your interior is gorgeous. I love that black and woodgrain look you have going on, my '79 interior looks terrible compared to that I wish I had the 2 large gauges instead of the rectangular gauge cluster over my wheel too.
Old Mar 3, 2009 | 08:42 PM
dmeesq's Avatar
dmeesq
What size gauges did you use?
Old Mar 4, 2009 | 10:47 AM
fauxrs2's Avatar
fauxrs2
5" speedo and tach, 2 1/8" console
Old Mar 5, 2009 | 07:28 AM
dmeesq's Avatar
dmeesq
Looks like the holes on the center console are 2 5/8 how did you fit the 2 1/8 gauges?
To Auto meter or Dolphin Gauges on 77?
