Anyone running solid motor mounts?
Old Mar 1, 2009 | 01:13 PM
Garys 68's Avatar
Garys 68
Default Anyone running solid motor mounts?
I'm in the middle of an LS swap. My adapter plates move the motor up about 1/4" from stock causing trans tunnel clearance problems. Flipping the plates would allow me to drop the motor 1/4" from stock.
Problem is that the rubber or poly motor mounts dont look like they would hold mounted upside down.
So I'm guessing I can use solid mounts upside down. Anyone using them? What's the downside, just more vibration? Is it that bad?
Old Mar 1, 2009 | 01:44 PM
73BLWN's Avatar
73BLWN
I switched to solid motor mounts years ago. I was constantly ripping my rubber ones in two. I'll never go back. I honestly can't say I noticed any significant increase in vibrations. My favorite benefit was my header and collectors don't loosen up and create leaks. I've seen this question posted before. Try a search. Good luck.
Old Mar 1, 2009 | 01:51 PM
Garys 68's Avatar
Garys 68
Yep, I did a search. A lot of posts about changing to them, then not much followup. Also, this is for an iron LS block. I'm assuming the 4 mounting points and cross bolted mains are better for stress on the block compared to a SBC. Wondering if anyone else had an opinion on this?
Old Mar 1, 2009 | 08:53 PM
Droshki's Avatar
Droshki
I love mine. Made by Moroso. Got them at Jegs I think. People said I would have vibration, but I dont, and I feel sooo much safer that my supercharged 383 isnt going to come flying out unexpectedly one day
Get you a VBP spreader bar too. Excellent company to work with.
Old Mar 1, 2009 | 09:23 PM
sm block's Avatar
sm block
3rd Gear
Hi new here to this great forum and this guestion caught my eye as I'm now tossing this very guest. around The info I've rec. is that sold mounts are fine for around 500 hp and down.After that block distortion comes into play.This has made me think of motor plates,being a drag only car.As always everone has a diff. opinion.
Old Mar 1, 2009 | 09:28 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've had Moroso solid mounts on every BB I've had in my '78, and would assume the reason for the relative lack of follow up being posted after installation is that there's pretty much no downside about which to complain. Strongly suggest the spreader bar, too. Agree about possible plate(s) for high power drag applications.
TSW
Old Mar 1, 2009 | 09:52 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I switched to Moroso solid mounts to avoid any engine movement because of the close proximity of the blower and hood... no discernable additional vibration...
Old Mar 2, 2009 | 04:12 AM
Garys 68's Avatar
Garys 68
Thanks for the replys, just ordered them (Moroso). I was fearing I would get a dozen, "I cracked my block" responses.
Old Apr 15, 2009 | 03:51 PM
bbeck's Avatar
bbeck
where is the best/cheapest place to buy the solid mounts? any difference amongst brands? or complaints about any?
Old Apr 15, 2009 | 04:01 PM
TheSkunkWorks
FYI, Moroso #62530 appear to fit all C2 & C3 applications. If you don't have a local speed shop source, Jeg's or Summit ought to have them for under $30. BTW, do NOT install a solid transmission mount, unless you happen to like cracked housings...
Old Apr 15, 2009 | 04:21 PM
bbeck's Avatar
bbeck
what's a part # for a rubber or poly trans mount? The only ones I'm finding right now are for automatics
Old Apr 15, 2009 | 04:43 PM
TheSkunkWorks
Unless you've got a 'glide or an M-40 automatic transmission, one cushion apparently fits all C2/C3's. I'll see if I can get you a GM #; Paragon's is #1519 for $9
edit - GM #3913498
Old Apr 15, 2009 | 06:46 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Never cracked my block but a few fillings fell out with the bang between gears when shifting. I went back to poly mounts and can shift normal now
Old Apr 15, 2009 | 07:02 PM
willem wallace's Avatar
willem wallace
Default Poly Mounts
Hey Motorhead,
I need to purchase some poly mounts. Sounds like you have put yours to the test. Could I get a brand and part number if you are running a small block?
To Anyone running solid motor mounts?
