I'm Overheating
Old Mar 1, 2009 | 01:36 PM
msandym's Avatar
msandym
Default I'm Overheating
All of a sudden , I've been overheating . I have a 71 w/ 350 . It overheats when I start , at idle . When I drive on PkWy , it cools down . Then stop and go , it overheats . It started a few weeks ago and has gotten worse . No leaks . Could it be fan clutch ?
Old Mar 1, 2009 | 01:46 PM
cargo247's Avatar
cargo247
i would think 4 things to look at, thermostat gone bad, lower rad hose spring gone bad, pump impeller rotted and not pumping, air lock.
you could need a good flushing?
Todd
Old Mar 1, 2009 | 01:55 PM
msandym's Avatar
msandym
Default I'm
Maybe . Thermostat - 180 - is new , pump is 3 years old , lower rad spring seems good , keeps roundness when I squeeze , I was thinking clutch fan because I can't seem to find much info or even where to buy ! Flushing sounds good to start . Thanks
Old Mar 1, 2009 | 02:19 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I would be looking at the clutch fan if it's running too hot when idling and runs cool when under way. When you say it is overheating is it actually boiling over? What reading are you getting on your gauge? Have you confirmed it's accuracy with an IR gun?
Good luck.
Old Mar 1, 2009 | 02:26 PM
wfo76's Avatar
wfo76
The symptom of overheating in the city but cooling on the highway points to an air flow problem.
Sounds to me like a fan, clutch, shroud, seals, etc. issue. To test the clutch, get the engine up to
full temp then shut it down, the fan should stop almost immediately. Should also feel resistance
when turning by hand when engine is hot, if not clutch is gone and needs replacing.
Old Mar 1, 2009 | 03:22 PM
tylershamilton's Avatar
tylershamilton
Double check and make sure it has water
Old Mar 1, 2009 | 06:24 PM
69small block's Avatar
69small block
Default overheating
be sure all seals for the rad are there seals for shroud are there too
Old Mar 1, 2009 | 06:28 PM
mikep3's Avatar
mikep3
I would check the fan clutch by running the engine at idle, shut it off and count the revolutions for the fan. 4 to 6 maximum or you have a bad clutch.
Old Mar 1, 2009 | 08:58 PM
msandym's Avatar
msandym
Default I'm
No , it didn't boil over . I was on PkWy , heat OK. Then , stop and go , heat slowly pins guage . I turned it off , opened hood , everything looks good . I tried to start , and starter wouldn't turn . Waited 15 min , car cooled down , started up , temp started to rise but I made it to PkWy. Heat went down , went home . Theres water , pump looks fine , no leaks or anything . Tomorrow I'll start testing things mentioned here . Thanks all !
Old Mar 1, 2009 | 09:17 PM
mikep3's Avatar
mikep3
That sound like the fan is not working, dose anyone agree on that?
A bad water pump, thermostat or radiator you would have high heat when stopped and moving.
Old Mar 1, 2009 | 09:49 PM
couperdecar's Avatar
couperdecar
Whatever we do , don't turn this into a thermostat thread. We'll have 50 pages in no time and everyone ****@d at each other again !
Old Mar 1, 2009 | 10:50 PM
SIXFOOTER's Avatar
SIXFOOTER
Almost certasinly a fan clutch or shroud problem. Start there. Rad seals would allow air to bypass radiator at hiway speeds causing heat. The clue is Idle/slow speed. About the only thing that will do that is air flow or the lack of it from the engine driven fan.
Old Mar 2, 2009 | 12:52 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i liked this one about being pi$$ed at everyone
Old Mar 2, 2009 | 07:48 AM
msandym's Avatar
msandym
Default I'm
Well , at first I thought of tstat , So I bought one , least expensive things first , right ? When I got home , pulled housing , no thermostat ! So I put the Slant 180 I bought in anyway , but it had been running OK for 3 years without it so thats not it . There , stopped that as a problem or issue . Well , theres a foot of snow in Malverne LI , so I'm just going to have a nice day inside . Thanks everyone . This forum is a great place but I do miss knowledge people like lars and durangoboy , but theres a lot others . Thanks again .
Old Mar 2, 2009 | 02:58 PM
BerniesVette's Avatar
BerniesVette
I have seen new t-stats be bad out of the box. You could have a vapor lock in the system. The front of the car needs to be up on ramps to force all the air in the system to the radiator cap where it can be expelled. Other than that, it sounds like a fan clutch problem to me.
Electric fans would cure that problem unless you just wanted to have the original fan on the car.
Bernie
To I'm Overheating
